navigator motor swap questions?
Old Apr 20, 2013 | 05:51 AM
capesteve's Avatar
capesteve
I have a 2002 navigator with a blown engine. I was going to swap the motor and transmission out of a 2000 navigator. Is it a straight forward swap or do i need the pcm/ecu from the 2000 as well? If i do won't i run into an issue with the chip in the key not matching the new pcm/ecu? Thanks.
Old Apr 20, 2013 | 11:02 AM
alloro's Avatar
alloro
No, you do not need the ECM from the donor vehicle. What you have to watch for is that the 2 transmissions are the same due to the electronic controls for the tranny.
Old Apr 20, 2013 | 12:32 PM
capesteve's Avatar
capesteve
ok thank you im pretty sure as long as its the 4wd the transmissions are the same. anyone know if there are different transmissions for these navigators?
Old Apr 22, 2013 | 02:11 PM
capesteve's Avatar
capesteve
ok one mo re thing. the donor vehicle and mine look identical engine wise but there is only one thing throwing me off making me wonder if the swap will work even though they are both intech engines is that the donor vehicle a 2000 the oil filter is located up on the bumper on drivers side and piped to the engine and the oil filter on my 02 is actually located up on the engine in the middle. Anyone know if this will still work?
Calebsdad7
Apr 18, 2019 11:20 AM
jlsellers
Aug 1, 2004 12:31 AM
DT 466Man
Engine Swaps
May 1, 2004 06:45 PM
