06 6.0 Advice
Old Apr 16, 2013 | 05:21 PM
Carnisedo's Avatar
Carnisedo
Talking 06 6.0 Advice
Hey all,
I bought a lemon truck in georgia last year it didnt even make it home before 2 injectors died and it wouldnt tow my jeep cherokee any further
Now after replacing 4 total along with the oil cooler, egr delete, 4" turbo back exhaust, and as of this month 2 brand new HPOP's I am asking what should go wrong next if anyone can guess? LOL
Truck Specs
2006 F-350 4 door dually Tow Boss XLT with 150k
Xtreme Diesel egr delete
APE Cold Air intake
MSRB 4" turbo back
Evo Edg Programmer probed in as well
It will do 7.5 in a quarter on econo tune and have gotten according to the Ford computer 19mpg with cruise set at 55.
Also whats the biggest size tires I could use on the dually rear before they rub?
Any advice of rear Wheel spacers? Pro? Con?
Whats the cost of re-gearing the front and rear? and is it worth it?
Thanks for any advice fellas!!!!!
Old Apr 16, 2013 | 05:49 PM
whiskey08's Avatar
whiskey08
I just dumped my 06 with 73k miles on it, traded it for a new 6.2 gasser
motor/turbo was blowing radiator fluid
when i tried to go over 60mph the motor would start to stall
had to cycle the key 5 times at least to get it to start then it took forever to warm up, (ficm?)
sometimes the entire instrument panel would go out
sometimes heater wouldnt work
fuel gauge wasnt working
so... gl
Old Apr 16, 2013 | 07:49 PM
99f350sd's Avatar
99f350sd
As with most 6.0's that tow if you want to keep it healthy you'll need to do all the mods that go with the 6.0L. Studs/gaskets/egr del/oil cooler/coolant filter/tuner/gauges/regulator spring/fuel additive etc.
Without towing you can get away with stock sometimes. Once you get it hot by towing all bets are off. Do it right or sell it. IMO
Old Apr 16, 2013 | 09:41 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Apr 16, 2013 | 11:38 PM
mustang_309's Avatar
mustang_309
For the 06 change the standpipes and dummy plugs to the updated parts as the original ones are known to fail and cause hot no starts. With you having had injectors fail I would do the fuel regulator blue spring upgrade which increases the fuel pressure by 10 PSI, the most common cause of injector failure is low fuel pressure. Switch to a full synthetic 5W-40 oil and make sure you are only using OEM/Racor oil and fuel filters and OEM air filter and make sure you have the OEM oil filter housing cap. Don't go cheap on the maintenance or you will pay big time down the road, keep up on the maintenance schedule to the letter. Next keep the electrical system in tip top shape, always change the batteries in pairs, low system voltage is what kills the FICM. Lastly get yourself some gauges that read live data like scan gauge II, Dashboss for IOS or torque for android so you are not flying blind and they are instrumental in diagnosing problems with these trucks.
Old Apr 17, 2013 | 07:48 AM
jdw1's Avatar
jdw1
My money is on the FICM!
Old Apr 17, 2013 | 09:31 AM
run6.0run's Avatar
run6.0run
I would guess that if your timing 1/4 miles, studs will be coming soon.
But,, I disagree with the lemon truck statement. I think you bought a used truck. If it was in tip top,, the previous owner prob would've kept it.
Brakes are prob up also.
2 hpop's??????? Um,,, If this is true,,, hate to say it, but you prob got took. In an 06 that is. Hell, I've dropped mine on the ground before, n it's still going with almost 700k.
Some great advice in previous posts. But if you wanna play hard with your truck,,, better have your wallet out. If the oil isn't changed on schedule,,, the injectors will be jumping outta the truck. Just some thoughts.
Welcome to our world!!! Lol
Old Apr 17, 2013 | 11:20 AM
Rusty Axlerod's Avatar
Rusty Axlerod
7.500 in a quarter mile and 19mpg?...Awesome! Whoever is working on your truck must have stacked those oil pumps .
A 8,000lb truck turning a 7.5 in a 1/4mi would be making 4,388 horsepower. Maybe that was a typo?
Old Apr 17, 2013 | 02:55 PM
_Me2_'s Avatar
_Me2_
Either that or he's had a few too many.
Old Apr 17, 2013 | 02:57 PM
diesel_dan's Avatar
diesel_dan
Troll comes to mind...
Old Apr 21, 2013 | 06:42 AM
Carnisedo's Avatar
Carnisedo
Talking
Sorry for the mis-info on the 1/4 mile I have never checked that it is 7.5 0-60 time,And yes both Hpop's I have done along with the oil cooler at the same time as the EGR delete I use my Edge programmer as a diagnostic tool as well since it has all the guages on screen and monitor my EGT's with it as well,I dont tow that often yet simply cause I havent bought a large enough trailer to use for work,I would like to hear more about the Fuel Regulator and Coolant filter upgrades I havent heard anything about these before.....
Old Apr 21, 2013 | 06:44 AM
Carnisedo's Avatar
Carnisedo
Oh it has a new FICM now though that wasnt what was wrong last time
Old Apr 21, 2013 | 08:51 AM
Rusty Axlerod
Ahh. 0-60 @ 7.5 sounds beter . Can you see FICM output voltage with your edge? If not there's a fairly quick way to check it with a meter. Test is in the Tech Folder.
If the FICM is ok I'd check fuel pressure next. The "blue spring" for the fuel pressure regulator isn't really a "mod" it was an update from Ford to address weak springs/lower pressure on some trucks. It's a good idea for any truck in my opinion. End result is it often raises fuel pressure 5-15psi. It's availabe from Ford and most aftermarket suppliers. Again, there's a thread in the Tech Folder.
The idea with the coolant filter is to keep any trash that might be in the cooling system out of the oil cooler. With the OC having the smallest passages in the entire system, it sort of becomes the filter. Every diesel place has a kit or You can put one together yourself. I understand most NAPA stores have all the parts. The kits are often billet aluminum and look nice and it's an easy install. A few considerations are the size of the hoses, wether it's plumbed in as a bypass filter or full filtration, and the filter type- spin on cartridge or washable/reusable.
Old Apr 21, 2013 | 03:59 PM
Carnisedo's Avatar
Carnisedo
Thanks Rusty thats some cool news on both things and the problem with my truck was fixed with the double HPOP installation but I put a new FICM in as well,I am planning on calling the mechanic tomorrow anyway(Hes a Ford 6.0 freak like me and has a truck that looks just like mine)and I will ask him about both the spring and the filter since when the front HPOP went it created some metal shavings then helped kill the rear HPOP but the oil cooler screens caught them as you pointed they are the catchall but was a large cost on labor due to pain of getting at it
Old Apr 21, 2013 | 05:42 PM
diesel_dan's Avatar
diesel_dan
I've never heard of a double High Pressure Oil Pump set-up, are you talking Low Pressure Oil Pump and High Pressure Oil Pump? I think we all were assuming you had just replaced the HPOP 2x.
On the Blue Spring (fuel pressure upgrade), it's easy enough that even I could do it. Riffraff diesel has a good price on the spring and o-ring and new brass plunger (and some other parts you don't need), but Extreme Diesel has just the spring and the main o-ring (seals the regulator cover to the unit) for under $30...
