Changed head gasket, still foaming
Old Mar 23, 2013 | 02:26 PM
'79 General's Avatar
'79 General
I just changed the head gasket in my 79 F100, 300 I6. After driving it about 100 miles, I have foam in the air cleaner again. I am also losing oil and antifreeze.
The truck never overheated when the head gasket blew the first time. It ran warmer after fixing it, but still did not over heat.
I looked the head over for cracks, and did not find any.
I am not sure what to do. Should I replace the head gasket again, or is there something else to check into?
Old Mar 23, 2013 | 03:29 PM
fordman75's Avatar
fordman75
When you replaced the head gasket did you check the head and deck to make sure they were both true/flat? If the head is warped it's not going to seal up without being machined.
And just because you can't see any cracks doesn't mean it's not cracked.
Did you check the block/cylinders for cracks?
Old Mar 23, 2013 | 03:54 PM
'79 General
I gave block, cylinders, and head a visual inspection. I did not check for flatness as it is a steel head, and it never overheated.
Old Mar 23, 2013 | 04:21 PM
fordman75's Avatar
fordman75
If you have the head off you always check it.
Old Mar 23, 2013 | 05:20 PM
xjfever's Avatar
xjfever
I agree, you should take the head to a machine shop and have it checked for warping and cracks.
gameover1974
19
Dec 18, 2015 02:15 PM
frenchy107
Mar 5, 2011 07:38 PM
bbsitum
1997 - 2003 F150
Jan 9, 2011 04:55 PM
fishin machine
15
Feb 2, 2008 07:39 AM
mckeelandscaping
Sep 1, 2006 05:35 PM
