Sway bar bushings and links replace
Old Feb 21, 2013 | 09:01 AM
allhuntalltime's Avatar
allhuntalltime
I'm changing the front sway bar bushings and links on my e99 today and need to know this is just a swap out no need to tension the bar or anything just take bar and links off change bushings put bar and links back on correct.
Thanks for any help
Old Feb 21, 2013 | 09:17 AM
01PS's Avatar
01PS
I bought new end links with the bushings already in. Unbolt, remove, replace, bolt in. I do not know of any tensioning needed. Others will chime in soon.
Old Feb 21, 2013 | 09:25 AM
allhuntalltime
I bought links with bushings in them also but the bushings holding the bar to the chassis have wear also (373k worth) so I am pulling the bar also.
I think its just remove and replace just wanted to check.
Thanks
Old Feb 21, 2013 | 09:40 AM
koski19's Avatar
koski19
Last month I installed Energy Suspension Polyurethane link and sway bar bushings. Took about 45 min. Around $30.00 Early 99 kit # is 4.5192R
After a month of driving that annoying clunk noise from the drivers side floor pan area is gone. I installed Ford replacement links in 2008 50,000 miles later replaced with Energy Suspension.
Old Feb 21, 2013 | 10:20 AM
Crewcab Turbo's Avatar
Crewcab Turbo
I replaced mine with Moog replacements from Autozone or O'rileys. I like the new design.
Chevmn56
Jul 26, 2013 08:02 PM
snowmobile mike
May 20, 2011 09:22 AM
rugermack
May 12, 2008 12:49 PM
boxcar1974
Apr 5, 2007 11:06 PM
Hoop
Jun 24, 2004 08:54 PM
