06/99 F250 7.3 fuel pump sputtering sound after filter change
Changed filter and now the pump makes a sputtering noise like its blowing bubbles in milk during its cycle before start. Also hear hissing from the fuel bowl unil it gains pressure then no noise no leaks and starts fine runs fine. new to FTE- sorry if i posted in wrong area which im sure i did. thanks for any help. i am impressed with this site and look forward to learning all i can about my truck.
I just took it to a "diesel performance shop" here where i live for a full diagnostic. They said the truck was pretty healthy other than the aih relay being out, which i replaced. I KNOW something is up though- black resdue/sediment in degas tank, coolant leaking from thermo housing and lower elbow oring, really dusted boots/engine bay, some type of flyid leaking off of starter/ tranny area, doesnt start as crisp, seems like she doesnt stand up like she used to. Now im far from a mechanic but for me to notice all that and them say noothing is wrong but aih relay and need a coolant flush seems odd. Osther than finding a new shop, any help would be much appreciated as i need to get back to work and work 1600 miles away!
They said oil cooler was okay and turbo was okay. Injectors, gpr and gps tested okay...
Fluid leak on starter and tranny is most likely oil in the valley of the engine. Look under the turbo with a light and see if there any puddles there. If so soak them up spray with a degreaser and give a good rinse. See where the oil is coming from. Mine needs a "Valley Bath" about every 18 mouths....
I cleaned the everything on the truck for like two days straight before i took it ro the shop lol and i havent seen anything major just coolant leaks i notice so far. shop said sludge was from the left over casting sand and to flush and get a filter installed. i also noticed a decent amount of black sludge/slime on intake and a little on the turbo wheel (i think thats just ccv gas- plan on kit and upate to a better intake. i work in ND so the truck runs 16 hours of every day of the year and i drive it like i stole it sometimes. also- its a six speed manual if thats matters? White smoke on start up especially if below freezing out too...
erik512
6.7L Power Stroke Diesel
33
06-06-2017 09:47 AM
mudracin74
02-07-2008 06:55 PM
yellowmatter
12-01-2006 05:43 PM
