Exterior Temp Reading - gone blank?
Old Dec 14, 2012 | 07:52 PM
BarnieTrk's Avatar
BarnieTrk
Hi Fellas,
My outside temperature reading on my '05 (6.0 PSD EB) Ex has recently gone black..no reading.
I haven't noticed any other issues, just no outside temp readings...
Do these sensors go bad or ?
Is it a big deal to change them out?
I was told it should be located just to the side of left hand (drivers side) headlight behind the grill, a small black cube (approx. 1 inch square) with three wires coming out of it. However, I'm not finding it there.
Where is the temp sensor located?
Is there a fuse covering this sensor?
Thanks in advance for any & all help and/or advice, Guys!
BarnieTrk
Old Dec 14, 2012 | 09:52 PM
Pickupmanx2's Avatar
Pickupmanx2
Hmmm... on my 99 F250, it was a resistor in the display that was the problem... might want to look there also.
Old Dec 14, 2012 | 09:58 PM
Sunline Fan's Avatar
Sunline Fan
Excursion Fleet Manager
So the inside temp adjustment/fan speed, etc. will show on the screen still?
Old Dec 14, 2012 | 11:05 PM
Pickupmanx2
Duh,,, I forgot the Ex's have it on the dash,,, haven't driven the wife's in a while!
Old Dec 15, 2012 | 07:21 AM
BarnieTrk's Avatar
BarnieTrk
Yep, all the rest of the normal screen display information is still there....
... which is why I was leaning towards the outside sensor unit being faulty...if I could locate it....
BarnieTrk
Old Dec 15, 2012 | 08:25 AM
Turfzilla's Avatar
Turfzilla
The sensor is behind the grill mounted on the drivers side header/grill and headlight mount.
Did you lose the entire readout or just the temp readout?
Old Dec 15, 2012 | 09:11 AM
BarnieTrk's Avatar
BarnieTrk
What do I have to do to get to it - remove the grill or remove the headlight assembly?
I have only lost the outside temp readout... Any fix ideas?
BarnieTrk
Old Dec 15, 2012 | 08:39 PM
Sunline Fan
BarnieTrk
Just remove the grill.
To remove the grill, since you have an '05: With the hood open, remove the little (I think) 5.5 mm screws that hold the top of the grill on. It should wiggle out a little on top.
On the bottom of the grill, there are four metal snap tabs. Get a flat blade screwdriver, put it between the bumper and grill, and lift up on the bottom lip of that tab. You kinda have to lift them up and pull on the grill- wiggle it out. Start at one end and work over. Eventually they'll all be free and you can pull the grill out.
FYI- the older grills are held on the same way, but they use larger phillips screws instead of the little bolt heads.
IIRC, the temp sensor is just pushed in with the little plastic Christmas tree clips.
Here's a pic of it:
The pic I actually googled for and is for the Zoodad mod. Drilling/cutting out the material in the pic helps to give a more direct flow of air into the intake on all Excursion/SD engines. The pic is pre-cutting.
Old Dec 17, 2012 | 09:57 AM
BarnieTrk's Avatar
BarnieTrk
Here's a pic of it:
Thanks for the reply, Sunline Fan!
Now there are two different looking parts listed at: RockAuto Parts Catalog ) under the category of: 2005 FORD EXCURSION 6.0L V8 DIESEL Turbocharged OHV : Heat & Air Conditioning : Ambient Air Temperature Sensor...., but - when I look through the grill with the aid of a flashlight, I can see neither style of sensor or anything located on that LH filler panel left of the radiator with a wire plugging into it. Where does the sensor wiring go back to...the headlight harness? Maybe I can trace the wire from ??? to the sensor.....
For what it's worth, I do know that this '05 Ex was in an accident (deer collision - previous owner, 3-4 years ago ) so maybe the sensor was re-located???? Wherever it is, it was working fine up until about a month ago.....
BarnieTrk
Old Dec 17, 2012 | 04:36 PM
Sunline Fan
I looked back at all my tear-down pics, and unfortunately I don't have anything from that area. I go from complete front end to nothing but radiators left.
I just zoomed in on a pic and found the sensor. The harness goes down along the bottom of the header panel. Actually, it might be behind the header and clipped to the metal behind it. So it would be behind the turn signal part of the left headlight. It doesn't appear to have anything to do with the headlight harness- it's completely separate. It goes into the engine compartment behind that headlight area almost to the left fender. It looks like the harness would lay on the inside of the fender liner plastic.
Front with header panel removed, but core supports still there:
The best first step would probably be to remove your left battery/tray and see if you find that harness that isn't going to the headlight. Unfortunately, it's a black harness like all the rest.
Granted it's a 7.3, but you can see the sensor hanging in the bottom right here:
Old Dec 18, 2012 | 02:17 AM
BarnieTrk's Avatar
BarnieTrk
Thanks for all your efforts, Jon!
Looks like locating this sensor will be a weekend 'seek & search' task for me!
I'll report back with what I determine............
BarnieTrk
Old Dec 18, 2012 | 07:39 PM
Sunline Fan
Sounds good, good luck in your search!
I sold the fog lights from the wreck to a member on here whose bumper and grill were replaced with Super Duty parts. His Ex originally came with fog lights, yet they were missing. We traced the foglight harness from the point where it plugged in back in the engine compartment, but it suddenly took a turn that mine didn't and we couldn't trace it. So we just unplugged the harness at the plug in and I sold him the harness I had since I didn't think I'd need it. It worked great then!
Xqsless
Jan 3, 2019 06:57 AM
Lubbockguy1979
Nov 27, 2015 11:26 PM
ssg510
Aug 5, 2012 12:56 AM
southbound35west
Aug 28, 2009 03:37 PM
