How much did RAS help with rear sag when towing
Old Sep 14, 2012 | 08:17 AM
mrad's Avatar
mrad
I installed a RAS in June. My TT has between 1,100 and 1,200 lbs of tongue weight. Without my weight distribution hitch hooked up, I am getting at least 3-4 inches of sag.
RAS rep told me each spring could handle over 1,600 lbs (3,200 total).
Shouldn't the RAS be doing a better job of holding up the load?
Old Sep 14, 2012 | 12:58 PM
tgreening's Avatar
tgreening
Your rear is still going to sag. How much depends on how much load you put on it. If its the same load as before the RAS, then you should be seeing less sag than before. If not you might have something installed/adjusted improperly. I'm not especially familiar with how you set it up.
Thing to remember is no matter how you look at it, it's a helper spring. When you add weight it's going to start to start compressing, and the rear end is going to start to drop. If you want to completely eliminate rear end sag you'll have to add bags.
Old Sep 14, 2012 | 04:45 PM
housedad's Avatar
housedad
sending you a PM in a few minutes, Mike.
Old Sep 14, 2012 | 05:36 PM
Tom's Avatar
Tom
I'm curious as to the reasons why many have opted for RAS, which is a fixed option that's not adjustable to the load, over adjustable systems like airbags.
Old Sep 14, 2012 | 05:55 PM
gr8scott72's Avatar
gr8scott72
Because it works great and it's cheaper than bags.
Old Sep 14, 2012 | 08:10 PM
LivingLarge's Avatar
LivingLarge
Well said!
Old Sep 14, 2012 | 09:01 PM
Tom's Avatar
Tom
Are they cheaper? The only ones I can find are $379.99, and both Firestone and AirLift bags can be had for under $300. Not trying to argue, just gain some perspective here.
Old Sep 14, 2012 | 10:51 PM
ExxWhy's Avatar
ExxWhy
I got the RAS as much for the stabilization properties as anything.
I don't know how much it helps since I had never hooked up the trailer prior to the install. With about 900 lbs tongue weight, I am getting less than 2" of sag with the WD hooked up, maybe 3 1/2 without. Wondering if you may not have the hitch tight enough?
Old Sep 15, 2012 | 08:49 AM
SMIGGS's Avatar
SMIGGS
What difference did the bags make for you? Besides leveling the Ex, was there a vast improvement in stability?
Old Sep 15, 2012 | 11:06 AM
Tom's Avatar
Tom
It's hard to say for sure because I only put 1,600 miles on it before putting the bags on. But from what I can tell after the bags an front springs it is every bit as stable as my '11 F350 was. I like the adjustability of the bags; I've had only 20 PSI in them since I installed them which provides ~1,000 lbs of lifting force and still rides decently.
Since I've never had RAS it's hard for me to compare, but I have a hard time understanding how they do anything more than stiffen the rear suspension a bit. Do these really differ from helper springs much?
Old Sep 18, 2012 | 09:35 AM
AirLiftCompany's Avatar
AirLiftCompany
SPONSOR
Hello mrad, if you want adjustability, we offer a 57340 kit for your 2003 Excursion 4WD. You can learn more about the system here: LOADLIFTER 5000; LEAF SPRING LEVELING KIT. Let me know if you have any questions.
Old Sep 18, 2012 | 12:30 PM
igotoneforya's Avatar
igotoneforya
Many of us (me included) purchased the RAS from a vendor for $130. It decreased my sag on my small trailer loads. Never more than 6-700 pounds tongue weight. I was getting a little sag which made it noticeable that rear was lower than front. Now it is closer to level when loaded.
Old Sep 18, 2012 | 07:44 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Ras helps a lot with wheel hop & axle wrap; Roadmaster Active Suspension Kits | Helper Springs | Overload Springs
Old Sep 19, 2012 | 07:09 AM
mrad's Avatar
mrad
I guess I was expecting the RAS to give my rear the suspension of a 1 ton truck. Thought I had read that 1-tons drop about 1/4" per 200lbs on the tongue. After I installed my RAS with springs just a bit further spaced than the quarter spacer, I am still getting 3-4" of sag before I hook up my WD hitch.
Old Sep 19, 2012 | 08:36 PM
Joe28443's Avatar
Joe28443
Joe28443
Mine bottoms out like 4" myself. I may try some bags and see how it goes
