Which rear sway bar
Old Sep 13, 2012 | 05:25 AM
Footy's Avatar
Footy
Which rear sway bar
I recently did the V & modded B code leaf springs to my 01 ex and all I can say is WOW! I knew the truck handled bad but the improvement was more than I Imagined. I got all of the parts from various junk yards. Everything worked except for the $20 rear sway bar I got from a 99 F350 with a service body. This sway bar was not even wide enough to reach both frame rails on my ex. Then I discovered that is was only about 3/4 inch diameter. Most of the research that I have read says to use the 30mm sway bar from a F350. So my question is which F350's use the 30mm rear sway bar? The choices are: 2wd srw, 4wd srw, 2wd dually & 4wd dually. Apearantly the service bod truck used a narrower frame.
Thanks in advance.
Old Sep 13, 2012 | 07:56 AM
ExxWhy's Avatar
ExxWhy
Easy way is to get a Helwig sway bar which includes all the hardware you need to hook it up.
Old Sep 13, 2012 | 09:48 AM
golfmedik's Avatar
golfmedik
X2....Love my Hellwig!
Old Sep 13, 2012 | 10:33 AM
timf150's Avatar
timf150
Footy,
Since you have the sway bar from the service body, do you know if the end links and the axle brackets will work?
If you still need to purchase all the hardware it may be an easier route to pick up the Hellwig as was mentioned by others in the posts.
I had a hard time getting the wrecking yards to sell just the axle brackets so I ended up buying the Hellwig.
Tim M
Old Sep 13, 2012 | 11:29 AM
Footy's Avatar
Footy
Originally Posted by timf150
Footy,
Tim M
The axle brackets did fit. The end links might.
Old Sep 13, 2012 | 11:51 AM
airjeff's Avatar
airjeff
I think mine was from an F350 SRW. I've hear that F250's with the camper package also had the 30mm.
If you can fine one at the salvage yard or already have the endlinks I'd say skip the Hellwig. As long as you some something better than stock you're good.
Old Sep 13, 2012 | 12:05 PM
timf150's Avatar
timf150
Well if you have all the parts already then you can pick up a new 30mm sway bar from Tousley for about $100 bucks.
Part number F81Z-5A772-AA
The only issue you may run into is the end links may be too long. This guy talks about it and ends up cutting the end links he got from an F350 and re welding them so that his bar is level.
Rear Sway Bar....will it fit? - PowerStrokeNation : Ford Powerstroke Diesel Forum
(don't like posting other forums but if it help a fellow FTE member I do)
Tim M
Old Sep 14, 2012 | 12:08 AM
jh818's Avatar
jh818
If you decide on Hellwig, the part number is in my signature.
JimPat
Feb 15, 2018 05:24 AM
Oscello
Oct 10, 2015 10:32 AM
Wilmax
Feb 4, 2013 09:28 PM
RAMPAGE_F350
Jan 5, 2008 08:36 PM
