Alternator question
Old Sep 11, 2012 | 06:32 PM
ShadowSnowLeopard's Avatar
ShadowSnowLeopard
Alternator question
So as of Sunday afternoon, the alternator light is staying on in the 1966. I put a meter on the battery while running and it read a solid 14.15 volts. Is there a chance there is something wrong in the wiring somewhere keeping the light on on the dash? Kinda afraid to take off too far till I dig deeper.
Thanks in advance guys!
1966 F100 Custom Cab
352 FE
Old Sep 11, 2012 | 06:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Check the fan belt, it may be loose. Alternator regulator has points. Look on its cover, see any dents?
Points got stuck, people rapped on the cover with their knuckles, screw drivers handles to unstick those fracatta points.
Old Sep 11, 2012 | 08:07 PM
Buzz44's Avatar
Buzz44
Agree with Bill sounds like stuck points in the regulator. The one in my 65 sticks a bit with a few quick revs it lets go. I probably should take the cover off and blow it out good it had been sitting on the shelf in my garage for over 20 years.
Old Sep 11, 2012 | 08:19 PM
smokenchoken's Avatar
smokenchoken
hmmm........ its fixable?........ my alt. light has been on the entire time owned and driven truck
Old Sep 13, 2012 | 02:44 PM
ShadowSnowLeopard
Haha! Well, I haven't tapped on anything yet, but I will try that this weekend. I guess so long as the gauge stays on the + side everything should be fine eh?
Old Sep 13, 2012 | 10:09 PM
smokenchoken
i've never had a low battery i didn't know if there was a fix for it
Old Sep 14, 2012 | 10:28 PM
ShadowSnowLeopard
Well I drove it to work and back today, about 75 miles round trip and no problem. The light stayed on the whole time but the gauge never dropped to the negative said. Guess I will just consider it decoration! Haha.
Old Sep 15, 2012 | 12:14 PM
NumberDummy
Light on, battery could be discharging. What's gonna happen when you're 35 miles from home and the battery is as dead as Julius Caesar?
If truck has a warning light, it doesn't have a ammeter gauge unless you added one.
Old Sep 17, 2012 | 12:14 PM
ShadowSnowLeopard
I fully agree Bill, there should be a locatable problem if the light is on. As for the dash layout, It does of a amp gauge. Whether it is original or not I do not know, but my configuration is like several other I have seen photos of. To the left of the speedo are the small gauges for current draw and fuel, to the right ar oil pressure and temperature. It also has the ALT and OIL warning lights
Like I said also, even with the ALT light lit, the ammeter reads on the + side and my voltmeter at the battery is reading 14.15 to 14.17 volts so I do not see how it could be discharging.
When I drove it Friday, the light went out for just a couple seconds as I pulled away from the house, then came right back on and stayed on the entire 70 mile trip.
James,
Old Sep 18, 2012 | 11:35 AM
rustywheel68's Avatar
rustywheel68
problem may be with the warning circuit, and not the alternator itself.
if you're running the stock charging setup, i think the wire that activates the warning lamp goes from the key switch, to the warning bulb, through the firewall to the "I" terminal on the external voltage regulator.
you may want to check those connections.
gatorjaws
Jan 14, 2019 11:22 PM
Stewart_H
17
Mar 18, 2016 08:58 PM
Camper Special Gene
Jan 29, 2015 07:50 PM
Dorsai
Apr 10, 2011 08:47 AM
mike
Nov 9, 1999 02:25 AM
