I have been following a thread in the Projects forum of a 1942 restoration. Nice build, even if it is in England. I did notice one thing, he is using copper as brake lines. Did the truck use copper brake lines in 1942? I didn't think copper would hold up to the pressure and it would split. I wasn't going to call him out on it if that was what they used back in '42. You can see them in post #35. Here is the link....https://www.ford-trucks.com/forums/1...-old-days.html
I have seen pre-cut copper lines sold for these year trucks, so I'm guessing if you really want the original look you would put them on. Remember that there isn't much pressure from the juice box master cylinder. Yes, I want steel but it's not my truck.
Steel lines were the originals. Copper is not a good choice, as it fatigues easily and is more prone to breakage. From what I have read, for racing inspections, as well as some safety inspections, if they see copper you will fail the safety inspection. It looks great, but in reality, its a poor choice for something as important as a braje system. Also remember, our trucks were single reservoir systems, break a line, and your braking ability is lost. I've experienced this...no fun at all. Praise the person that decided to create emergency brakes.
I remember reading somewhere that some break lines were made by rolling sheet steel with a layer of copper on them. They were rolled together to make a "Seamless" tube with the copper fusing it together. It may be some of that material. The lines on my 1-1/2 ton look "Coppery" I will check them with a magnet to see if it sticks.
