No power and long crank
Old Jun 6, 2012 | 05:22 PM
dvskate's Avatar
dvskate
I got a 2006 f450 with egr delete that has a long crank and when it fires it seems to run fine but when you drive down the road the turbo just screams and it doesn't go more than 15 mph and it will shoot air back through the intake if you try to romp on it. I'm not sure where to start there's no codes. Any ideas would be much appreciated.
Old Jun 6, 2012 | 06:02 PM
dvskate's Avatar
dvskate
Just got a good scanner and it has p0299 tc/sc under boost and po478 exhaust pressure control valve high
Old Jun 8, 2012 | 05:22 AM
npccpartsman's Avatar
npccpartsman
Start with cleaning the turbo and exhaust back pressure valve/tube. Check the MAP sensor tube for plugging. Also check the CAC tubes/boots for splits and the turbo air system for leaks while you have the turbo out. There is a cleaning procedure posted in the 6.0 tech folder.
Old Jun 8, 2012 | 08:11 AM
dvskate's Avatar
dvskate
It blows the cac boot off right from the turbo every time I drive it
Old Jun 8, 2012 | 09:38 AM
BLADE35's Avatar
BLADE35
Tim is probably right turbo needs clean
But I would check Baro & MAP & EBP & MAF sensors at KOEO and low I del and High Idel
mikeeg16
Jun 29, 2013 12:40 PM
utjer
May 19, 2013 08:39 AM
05whitef250
Sep 6, 2010 01:47 PM
deercreek1
Feb 22, 2008 11:23 AM
s_focht
Jun 25, 2007 07:59 AM
