Offroad & 4x4
2 wheel drive to 4 wheel drive
Old May 5, 2003 | 06:08 AM
The Weezle's Avatar
The Weezle
I have a 1986 Ford F150 with a 5.0 liter Efi v8,C-6 Auto trans. and would like to make it a four wheel drive. I have found a 1988 Bronco complete with everything there and working. what I need to know is will this fit on my 86 F 150 as a bolt up or will I have to make major modifications?
Thanks
Carl
( The Weezle )
Old May 5, 2003 | 05:28 PM
electricmaniac2's Avatar
electricmaniac2
The front crossmember is different for the 4WD along w/ a few other things....it IS possible to convert it, but it's not a driveway conversion...if you're good w/ cutting, welding and fabrication, it's a good project.
Old May 5, 2003 | 05:50 PM
RBrendel's Avatar
RBrendel
its all bolt up. search for threads containing this information. and yes it can be a driveway project. the bronco will work im pretty sure of it. its supposed to be pretty easy.
Old May 5, 2003 | 11:02 PM
MustangGT221's Avatar
MustangGT221
Yup, theres no welding or fabrication involved. There is a tech article on this site. Click the link on the right. It's really a pretty simple thing, just time consuming. I was going to do it but my truck was totalled before it happened.
Old May 6, 2003 | 02:27 PM
cek181's Avatar
cek181
its easy as pie, takes about 2 hours if you have some buddies and know what your doing. 2 wd stuff drops out and 4x4 stuff bolts right in place.
Old May 6, 2003 | 10:51 PM
electricmaniac2
I apologize to all for my mistake....For some reason, I was still thinking about the solid axle swap a friend and I were talking about earlier in the day. Yes, I agree. the TTB swap is all nuts and bolts. Good luck!
Michael L
1997 - 2003 F150
May 16, 2016 08:31 PM
Michael L
Projects
Apr 9, 2016 05:03 PM
Donald Edmonton
2009 - 2014 F150
May 30, 2014 09:57 PM
mustangman711
Mar 1, 2009 10:18 AM
01F150SCCwboy
Offroad & 4x4
Feb 18, 2006 07:52 PM
