Front end noise
Old Mar 1, 2014 | 11:57 PM
Donald Edmonton's Avatar
Donald Edmonton
Front end noise
Wife's 2010 F150 4x4 85000 KMs makes grinding / ratcheting noise in LH front axle when in 2 wheel drive. Mostly when turning left some times when traveling straight never when turning right. Never makes the noise when in four wheel drive.
I am suspecting the auto hub is the issue but wonder if others have had this trouble ?
Old Mar 2, 2014 | 07:37 AM
NASSTY's Avatar
NASSTY
If the noise goes away when you engage 4x4 than it is probably a hub or IWE.
Old Mar 2, 2014 | 09:41 AM
Pool Runner's Avatar
Pool Runner
What's the story on this issue, I am reading more and more problems with these front hubs.
To me it seems so widespread, that it's not a matter of if they will fail but when. I never worried about this with my 2011, as it was a 2wd. But I got to admit, I do worry a little for my 2013, FX4. I'm sure this is a costly item to repair outside the warranty period.
Old Mar 2, 2014 | 02:25 PM
Donald Edmonton
short term fix
My garage is full and it is too cold here to replace the IWE unit today. I have disconnected the electrical connector from the IWE solenoid. This should leave both hubs locked in but still allow the transfer case to shift to 4x2. This will spin the front end when in 4x2 and eventually wear something out but it will be fine for a couple of weeks communing to work. I went for a test drive and this has not caused any warning lights so think it is OK for a bit. When it warms up I will change the IWE vacuum clutch. I found good youtube video showing how to remove the half shaft then the IWE unit but the video shows a half shaft that bolted to the drive axles (inner end of half shaft) with 6 cap screws. The 2010 I have is not a bolted flange. Will have to keep looking for video that matches this truck.
Old Mar 28, 2014 | 11:21 PM
78150custom's Avatar
78150custom
Check your vacuum lines to the hub. Where they are zip tied to one of the brackets, they are known to tear. Had same issue on my 2010 f150.
Old May 30, 2014 | 09:57 PM
Donald Edmonton
Turns out it was a cracked vacuum line, the heavy rubber one to the LH wheel hub. Easy fix !
thanks for the help
LiberationKing
Sep 25, 2016 10:44 PM
jdecker
Nov 2, 2008 09:56 PM
Geekboy1990
Oct 15, 2004 12:45 AM
jphatem
Offroad & 4x4
Mar 3, 2003 06:10 AM
jphatem
Feb 25, 2003 11:39 PM
