1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
5.4 motor, 4.30 gears, maybe want to run 35's?
Old 04-06-2012, 10:54 AM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
i need new tires on my 2004 F350 soon, im running 285/75R16 now and in no way am i putting that size back on again. I found a set of 255/85R16 BFG mud terrian KM2 for $750.00, now i dont tow to max anymore but i do tow a 20ft CC boat on a dual axle trailer, i do still have my 16ft trailer that i load up with mulch, topsoil, cut food, etc through the year. But since my truck is leveled and has the room for a set of 35 inch tires i was wondering how it would do turning the 35's with 4.30 gears? What will my ratio be with the 35's? Back to 3.73 or lower like 3.55? Also im getting around 12mpg around town how do you's think ill do IF i go to 35's afterwards? Thanks
Old 04-06-2012, 02:32 PM
cartmanea's Avatar
cartmanea
cartmanea is offline
A leveling kit doesn't clear 35s all that well, especially if you flex it a little. I think you'd be a lot happier sticking with 33s with a 5.4L and 4.30s. Really, a 5.4L should have 4.30s stock and with 35s I'd lean towards 4.56 or 4.88.
Old 04-06-2012, 02:46 PM
onebadv2's Avatar
onebadv2
onebadv2 is offline
I have an 03 F250 with a 3" lift and 315 Toyo MT's which when new measured out at 35.2" tall. The only time I rub is when I am at full turn in the front an I think a small triangle cut on the bumper would solve it. I also the 5.4 with the 3.73 ratio. I am saving up for the 4.30's. The jump in tire size really....really made a difference in the power department at take off an in the mpg area. Right now I get 9.5 or at best 10mpg.
Old 04-06-2012, 02:56 PM
cbzdel's Avatar
cbzdel
cbzdel is offline
the only time I rub with my 35s is at a full left turn, and it just rubs on the plastic wheel well liner.. I guess it all depends on your wheel tire combo..
maybe its a typo, but a 255/85R16 its only a 33x10 tire?? And your 285/75R16 is a 33x11 tire, so really your looking at just getting a narrower tire, not a larger diameter one?
Old 04-06-2012, 09:06 PM
92f150I6's Avatar
92f150I6
92f150I6 is offline
In the summer i have 305 70 16's and 4:10 gears. have towed a car hauler with my race car on it no problem, isn't fast, but I can run on the highway no problem.
Old 04-06-2012, 10:13 PM
cartmanea's Avatar
cartmanea
That's only about 5-6k though.
Old 04-07-2012, 03:53 PM
SuperDutyScaler
for some reason the 255/85r16 KM2 is 33.7 inches tall from BFG website, and from other sites that had these tires listed. My BFG All terrain's i have now are 285/75r16 are 32.4 inches, but yes i want just a slightly taller tire but i want it closer to stock width which the 255 will give me. Just wanted to see how bad my 5.4 would do with 35's even though i have 4.30 gears.
Old 04-07-2012, 03:54 PM
SuperDutyScaler
well it looks like ill be buying the 255/85 and ill post a ton of pictures, not many on here in that size even though i read alot of guys run them
Old 04-07-2012, 04:38 PM
acf6's Avatar
acf6
acf6 is offline
sweet... im getting some used cooper stt 35x12.5x18s with MT classics for my truck soon so im gonna run em
Old 04-08-2012, 09:25 AM
SuperDutyScaler
[quote=cbzdel;11675503]the only time I rub with my 35s is at a full left turn, and it just rubs on the plastic wheel well liner.. I guess it all depends on your wheel tire combo..
quote]
my new pro comp springs flex wwaayy better than the stock ones could ever dream about, i can completely stuff one front tire and the opposite rear tires now and my 285's just clear and have about 3/4" of clearance between them and the front inner liner?
Old 04-09-2012, 08:11 PM
92f150I6's Avatar
92f150I6
92f150I6 is offline
Not trying ti be an ****, but so is a 20 ft boat. I have one myself with I/O engine, pulls just fine with 33's and 4:10's. But, i do have a single axle trailer. maybe that is a difference?
Old 04-09-2012, 10:10 PM
cartmanea's Avatar
cartmanea
What I'm saying is pretty much any configuration of Superdudy can pull 5-6k, so there's no reason to question or debate it. In fact, a f150 could handle it fine. And given the same weight on the trailer and tongue, axle count makes no difference in how the truck handles it, except a tandem trailer may have more braking ability.
Old 04-09-2012, 11:02 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
at stock height would 33" tires not rub? ive got an 04 but i did the 05 front end conversion if it matters i think the rime im looking into are 9" wide thier the moto metal 951 rims just curious because im in the same situation as Scaler my tires will be worn out in the next few months.
Old 04-10-2012, 02:56 AM
cartmanea's Avatar
cartmanea
You shouldn't have any trouble with a 33 unless they are ridiculously wide or have high negative offset wheels that stick out really far. When I got my '03 it had 315/75r16s (35x12) on it at stock height with -6mm offset wheels and they didn't rub.
Old 04-10-2012, 06:08 AM
xmontex4's Avatar
xmontex4
xmontex4 is offline
Cool, ive been trying to find that out forever thanks!
Quick Reply: 5.4 motor, 4.30 gears, maybe want to run 35's?
