Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F-550
Old Mar 20, 2012 | 09:29 PM
Vinford's Avatar
Vinford
F-550
Does anyone know the GVW and the weight of a F-550?
Diesel reg cab with a 12 foot deck.
Old Mar 20, 2012 | 10:56 PM
85e150's Avatar
85e150
Should be on a plate or sticker on the door or door jamb.
VIN may have GVWR coded or axle ratings.
Old Mar 21, 2012 | 12:35 PM
Vinford's Avatar
Vinford
I dont have the truck Im trying to figure out how big of truck I need to be legal to haul my Bobcat.
Old Mar 21, 2012 | 01:23 PM
LSchicago2's Avatar
LSchicago2
GVW will vary between 17.5-19.5. Empty weight can vary a lot more, from about 9,000 pounds to 14,000 pounds depending on what's bolted to it.
Old Mar 21, 2012 | 07:29 PM
Parts Jimmy's Avatar
Parts Jimmy
A F550 will easily pull the largest skid steer without issue.
Old Mar 21, 2012 | 08:02 PM
Vinford's Avatar
Vinford
I dont want to pull it I want to haul it.
Old Mar 21, 2012 | 08:05 PM
Vinford's Avatar
Vinford
Kinda what I was wondering its to light I think.
Bobcats around 9000 lbs and if the trucks 12,000 lbs that puts me over the GVW
Old Mar 21, 2012 | 10:42 PM
cj06's Avatar
cj06
a F550 will handle a bobcat on the back , use to haul a 580 case backhoe on the back of a older F600 and that was scary !
with a F550 you will have a better braking system than the old F600 had !
and you will still be under the 26,001 GVW for a commercial drivers license if that even comes into play up where your at !
Old Mar 21, 2012 | 11:19 PM
Vinford's Avatar
Vinford
It doesnt look like the 550 has enough GVW for what I need to be legal.
Is there a 650 or is the next biggest the 700?
Old Mar 21, 2012 | 11:31 PM
85e150's Avatar
85e150
F650s will run over 21000. This is 2012, but previous years aren't going to be drastically different:
2012 Ford F-650/F-750 Work Trucks | View Full Specification Library | Ford.com
Not sure what you're doing, but consider a single axle rig with a roll off:
Buy A Truck used trucks, trailers and equipment for sale
for example.
You use the roll off unit for whatever, and then drive the Bobcat into it, then pull the whole mess on to the truck. (as I've seen a local outfit do)
Having said that, that particular outfit uses tandem axle cab-over trucks and they will take a low sided dumpster full of busted concrete off your hands with ease with one of those.
Old Mar 23, 2012 | 01:01 AM
rummur s.c.'s Avatar
rummur s.c.
What bobcat do you have? My 753 only weighs 5000 lbs.. You must have a monster..
you'd need a 700 for a 5 ton payload.
sdinenno
May 2, 2015 12:37 PM
ford40
Mar 24, 2014 07:08 PM
BignastyGS
Mar 6, 2012 07:02 PM
f350rebel7788
May 17, 2011 07:38 AM
FiveO
Jan 22, 2003 11:17 AM
