i want to put a stroker crank in, match it with a cam not sure which direction to go on a cam, and long tube headers. was told that i can put 428 cj heads on but dont know if its true or not. my biggest question is where to start with timing. i know 360's like to ping.
i was also told by ford guys to locate a 77-79 half ton for its front and rear axles. i was told to do this because of more durable diff and front disc brakes. can you confirm this?
In one word..... yes! Don't forget to get the proportioning valve for the front disc brakes when you swap axles. You will need it for the disc brakes to work properly.
