mirror directional bulb
Old Feb 15, 2012 | 10:16 AM
gsxr1300's Avatar
gsxr1300
I think I have a bulb out in my passenger mirror the lower part doesnt light up but the top does.
Is this 1 or 2 bulbs and is it hard to change it?
Old Feb 15, 2012 | 10:57 AM
Specularius's Avatar
Specularius
The lower bulb is the turn signal. It will only light up when the turn signal is active.
Old Feb 15, 2012 | 11:05 AM
gsxr1300's Avatar
gsxr1300
Sorry whatever one comes on with the headlights isnt coming on
Old Feb 15, 2012 | 11:19 AM
darren32's Avatar
darren32
There are 2 bulbs in there, see pdf files c/w part numbers etc
Thanks
Old Feb 15, 2012 | 11:22 AM
gsxr1300's Avatar
gsxr1300
Cool thanks
Old Feb 15, 2012 | 05:16 PM
gsxr1300's Avatar
gsxr1300
if im reading that correctly you don't need to remove the glass right right?
Old Feb 15, 2012 | 08:32 PM
darren32's Avatar
darren32
That's what I get from it, just adjust the glass to the all the way in position and you should be able to reach behind it and get at the clip. Never done it though.
Thanks
Old Feb 15, 2012 | 10:06 PM
golfmedik's Avatar
golfmedik
If it is like the 08-10s which I believe it is, power your mirror to the inside and take a flashlight and look behind the outside edge. You should see a silver tab. Take a long slender screwdriver and push that tab towards the front of the truck while holding onto the mirror with the other hand. It should pop and the light fixture should pop out. After changing the bulb(s) just push it back into place while holding the mirror still.
Old Feb 16, 2012 | 09:43 AM
gsxr1300's Avatar
gsxr1300
Thanks for all the help I popped the lens off and the bulb was loose in it so I put it back in the socket and works great now
captain1997
1997 - 2003 F150
Dec 8, 2015 09:17 PM
Midwest Dually
6.4L Power Stroke Diesel
Nov 9, 2013 01:28 PM
Fastfwd
Aug 22, 2013 10:02 AM
brow603
1997 - 2003 F150
Sep 1, 2007 04:14 PM
edheiser
Oct 2, 2006 11:14 AM
