motor shaking when stop
Old Feb 15, 2012 | 05:30 AM
ahmad's Avatar
ahmad
i bought recently expedition 2005 but i have this problem
Old Feb 15, 2012 | 06:24 AM
critterf1's Avatar
critterf1
A little more information "might" be helpful.
Old Feb 16, 2012 | 02:13 AM
ahmad's Avatar
ahmad
when i stop am feeling that the car shaking from the engine
Old Feb 16, 2012 | 07:01 AM
critterf1's Avatar
critterf1
Is the "CEL" light on? What engine? Mileage? Any maintenance history?
Old Feb 16, 2012 | 11:24 AM
lv2race's Avatar
lv2race
Plug in a scanner and check for codes.
Old Feb 18, 2012 | 08:00 AM
jimvw57's Avatar
jimvw57
most likely a coil pack.
Old Feb 19, 2012 | 01:17 AM
ahmad's Avatar
ahmad
thanx for the reply i have only this errors
1-check fuel cap.
2-moniter fualty error in tires.
Old Feb 19, 2012 | 01:22 AM
ahmad's Avatar
ahmad
before i start the car it is showing me cel light on orange but after starting it is gone.
106 mile
regarding maiontanance i dont know becouse i bought it recently
Old Feb 19, 2012 | 08:25 AM
jimvw57's Avatar
jimvw57
You won't always get an error code for a coil pack if it is intermittnt. They will short out when they are cool and have moisture on them and work fine once they get warmed up and the moisture dries off. Once it gets bad enough to short all the time, the error code will show up.
The other thing you might have is a slight vacuum leak form a deteriorated hose. They are usually worse at idle.
Old Feb 19, 2012 | 12:46 PM
lv2race's Avatar
lv2race
Did you plug in a scanner like I suggested? You said errors, what were the codes?
Spark plugs need to be changed at or before 100K, if that wasn't done, the car will start to run as you described. I had to change mine at 97K due to poor idle. Check all the EVAP lines by the fuel tank and check the fuel filler hose under the car for cracks. I don't think you have an IAC that needs to be cleaned. Other experts can tell you when Ford stopped putting those on, I think 04 was the last year. All dash lights will illuminate before you start the car and go off unless you have a problem.
Since you don't know the history and you're in the desert, change the fuel and air filters and spark plugs (the long terrible ones?) and see if that makes a difference. If you still have the problem, we can help chase it down. Then I suggest you change all of your fluids for your own peace of mind.
Old Feb 20, 2012 | 05:29 AM
ahmad's Avatar
ahmad
thanx alot i will try that and i will reply
donaldm
1983 - 2012 Ranger & B-Series
Dec 18, 2012 12:47 PM
0ne_sik_70SWB
Mar 10, 2012 03:44 PM
Ace!
Jan 20, 2010 06:40 PM
john fin
Aug 26, 2007 09:40 PM
fishinbum
Ford vs The Competition
44
May 30, 2003 08:52 AM
