4 speed overdrive?
4 speed overdrive?
As far as I know, any transmission off of a Ford 302 or 5.0 will fit behind any other Ford 302 or 5.0--the bellhousing pattern is always the same. As for the truck, however, there may be a few modifications involved. I'm assuming that the 4-speed is a toploader, and if so, it should be a bolt-in swap. Anyone else maybe know a bit more on this?
Anthony
Anthony
4 speed overdrive?
It probably is a SROD. i have heard some say that they are not too strong. I don't have a high horse mill, 140 Hp and 240 ft-lbs. The 5.0 it was behind was built, maybe 200 hp, but the tranny is in good shape according to the guys son, who drove it a for a week before it got wrecked. My main concern is if it will fit in place of my current 3 speed without a different length driveshaft. The overdrive 4th will be a welcome addition, as most of my milage is on the interstate or highway going about 70-80, and my loud exhaust is not very pleasent at that speed, even with 3.25 gears.
4 speed overdrive?
Originally posted by muchtomydelight
RUG BP
RUG CL
RUG CD
RUG CA
The easiest to spot is the 4 bolt bell housing of the SROD (single-rail-overdrive) and the speedometer pickup is on the passenger
RUG BP
RUG CL
RUG CD
RUG CA
here is the david kee page on orion overdrives:
http://www.4speedtoploaders.com/imposters.htm
and here is the only web picture i could find of a SROD:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2421862680
and to try and answer the original question, yes you can use the late model 5 speed (4 O/D) on your older engine as long as you have the correct balance and diameter flywheel. ford has two engine balance figures (28 and 50 oz) for the 302 and several tooth counts for flywheels. basically all you will need to do is count the number of teeth on the late model flywheel and then get an early flywheel that size. it is really quite simple and easy. hawkrod
4 speed overdrive?
I saw that the picture you gave was from an ebay auction in grovetown, about an hour drive from here, so I may buy that one, or another if the price is right. My question is if I could use my flywheel I have now. I also have a clutch with only less than 2500 miles on it. Will all of this be usable? I am fairly sure that my drive shaft will have to be cut, but I have an uncle that will do that for cheap, and I can move my trans. crossmember with no trouble.
4 speed overdrive?
i would not recomend using a SROD transmission for anything other than keeping the barn door open in a breeze. they are famous for blowing up behind 4 cylinder 2.3 mustangs. a SROD would never hold up in a pickup with good gears as the torque multiplication and weight of the truck will shatter the transmission gears like glass. hawkrod
4 speed overdrive?
Oh well, the search continues. The other tranny I am not sure of the type. It has a case that *looked* like the toploders, and the shift pattern is
1 3
|_|_
2 4 R
It was not the original motor or tranny, the VIN says it was a 177 V-6, and I could only see the tranny from under the hood. I am going to look at it this weekend, so when I get a positive ID, I will post it.
1 3
|_|_
2 4 R
John with beastly 302
15
03-21-2022 11:31 PM
rmark940
05-27-2009 11:54 PM
Dustincoc
07-11-2008 08:10 AM
jdbanks
05-16-2005 07:49 PM
4, f250, ford, ford4, manual, od, overdrive, overdrives, rail, ratios, rugsrod, single, speed, speedwithoverdrive, transmission
