4wd tries to self engage
Old Dec 29, 2011 | 10:29 AM
walt j's Avatar
walt j
2008 f150 5.4 4wd 22,000 mi driving normal get grating noise sounds like xfer case trying to engage, turn 4wd *** to 4wd hi then off noise goes away. Sometimes it happens several times in one day then nothing for months. Apreciate any ideas. Thanks Walt
Old Dec 29, 2011 | 10:37 AM
xjcamaro89's Avatar
xjcamaro89
Check out the link in my signature, Everything you wanted to know about the IWE system and then some.
Sounds like a vacuum issue somewhere along the lines for the 4WD.
Old Dec 29, 2011 | 10:40 PM
walt j's Avatar
walt j
Thank you for the quick reply. Walt
Old Dec 30, 2011 | 06:44 AM
xjcamaro89's Avatar
xjcamaro89
Let me know if you have any questions, i can practically fix the IWE system in these trucks in my sleep
Old Dec 30, 2011 | 06:58 AM
60DRB's Avatar
60DRB
...he ain't lyin'!!!
Old Dec 30, 2011 | 09:55 PM
NDFARMCHAP's Avatar
NDFARMCHAP
Had the same problem with my 04 f150 like he said sounds like a vaccume problem. That what mine ended up being, found it after gave up on the dealer as it was under warrenty. They replaced killed hubs 7 times and never fixed it, turned out had a torn vaccume line at the hub, would also look at solenoid as they are problematic also. When i did mine the dealership gave me the parts as was on warrenty yet and i replaced both hubs, vac lines and solenoid never had another front end problem but wont talk about trans.
Old Jan 3, 2012 | 11:34 AM
gpeade's Avatar
gpeade
If its like mine its actually a hub partly engaging. You either have a vacuum leak or a moisture issue. At least that what my problem was. I made a hood to cover my solenoid and after a month or so it apparently dried up and havent had any more issues. This was three years ago and everything works fine currently.
Old Jan 6, 2012 | 05:38 PM
jbc19d's Avatar
jbc19d
Had a similar problem like this. It was trying to engage and made a racket like those old things you put on bicycle rims way back in the day that hit the spokes and made the crazy sound lol...best way i can describe it. It was a vacum problem but not a line. Im not sure of the correct name of it but i think its called the hub accuator on the inside of the wheel. Its round and has two vacum line going to it. I can take a picture of it tomorrow and send it to you if you want. It took the shop about 2 weeks to identify the problem! Might be your problem, might not be but its worth checking into i think.
Old Jan 7, 2012 | 10:59 PM
walt j's Avatar
walt j
Replaced IWE solenoid today, also checked vacuum 21 at idle coming off engine before check valve. Drove truck and no noises hopefully its good, thanks xjcamaro89 for info and help. Walt
Old Jan 8, 2012 | 09:45 AM
xjcamaro89's Avatar
xjcamaro89
Glad to hear it
koboss1
2004 - 2008 F150
Apr 3, 2009 06:49 PM
trygger
Mar 12, 2008 07:36 AM
Quackhead94ranger
1983 - 2012 Ranger & B-Series
Nov 1, 2004 10:41 PM
calzone
Bronco II
Dec 5, 2003 04:56 PM
