300 I6 Distributor recurve
Old Nov 15, 2011 | 06:30 AM
nlareau's Avatar
nlareau
Can somebody tell me where to set the timing on a daily driver 1977 300?
My vacuum advance is way wrong somehow and I have it disconnected. If I had a perfectly functioning system what should the settings be?
8 BTDC for idle?
20 BTDC at 2000?
I don't know what "stock" is, so I don't know what to change. Any help would be appreciated.
Old Nov 15, 2011 | 09:40 AM
Harte3's Avatar
Harte3
Set to what the engine "likes"...with a vacuum gauge. Advance the dizzy to the highest steady reading and then back off 1-2 hg. Adjust the carb idle mix to the highest steady reading and then adjust the idle speed. Go back through that routine again. You are now at your starting point. Drive it and see if it take more advance or needs less. Adjust accordingly.
Old Nov 15, 2011 | 10:50 AM
AbandonedBronco's Avatar
AbandonedBronco
Unfortunately, with the stock timing marks, it's difficult to see the timing beyond around 14° advance.
But, as Harte3 said, disconnect the vacuum advance and time it by vacuum. It gets the best results.
Then, reattach the vacuum advance and go for a drive. If overall it feels good, but pings under heavy acceleration, you can readjust the vacuum advance canister by sliding a hex wrench in the end (I think it's a 3/32") and turning it. I believe counter-clockwise makes the timing come in later, clockwise = sooner. It's around 1 - 2 full turns for 1hg of vacuum sooner, so don't be timid with your adjustments.
rsh1966
Jul 23, 2019 08:08 AM
‘66 F100 Pearl
Feb 19, 2019 09:37 AM
jbcww
Nov 15, 2018 10:53 PM
Scott Yager
36
Jul 21, 2017 09:34 AM
btravis90
Feb 8, 2012 11:24 AM
