Sponsored by: Real Truck
front brakes dragging ' F350 58k
Old Oct 25, 2011 | 09:16 AM
rick52's Avatar
rick52
my front brakes seem to be sticking. I pulled the wheel off and rotor turns by hand but is dragging. Is it supposed to be touching the brake pads??
Old Oct 25, 2011 | 12:31 PM
senix's Avatar
senix
Grease the slide pins on your calipers. Those pads should be right up agains't the rotor but no much that it creates a drag.
Old Oct 25, 2011 | 01:46 PM
Boss08v10's Avatar
Boss08v10
My front passenger side rim is always dirty with brake dust before the other three, the truck does not pull one bit and it does not seem to be dragging. I know my 06 psd had a much different feel to the breaks and this 08 takes more pedal pressure. Not sure what to look at or fix. 53000 miles on the truck.
Old Oct 25, 2011 | 03:58 PM
jbrunel's Avatar
jbrunel
My 02 f-250 had a problem with the right front also..It turned out to be the caliper not fully retracting
Old Oct 25, 2011 | 08:17 PM
ampslw's Avatar
ampslw
try this
take the brake cappler off and take one brake pad and a big c-clamp and push the piston back in
now it will take a bit of force but not a lot if it is very hard to get the pistons to go back in replace the cappler
now after that Grease the slide pins on your calipers
<TABLE style="BORDER-TOP-WIDTH: 0px" class=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center><TBODY><TR title="Post 10960742" vAlign=top><TD class=alt2 width=125 align=center>senix</TD><TD class=alt1>Grease the slide pins on your calipers. Those pads should be right up agains't the rotor but no much that it creates a drag</TD></TR></TBODY></TABLE>
Old Oct 25, 2011 | 08:18 PM
ampslw's Avatar
ampslw
try this
take the brake cappler off and take one brake pad and a big clame and push the piston back in
Old Oct 25, 2011 | 08:20 PM
ampslw's Avatar
ampslw
try this
Old Oct 25, 2011 | 08:42 PM
FireMe's Avatar
FireMe
You also need to make sure the pads are not binding in the caliper bracket, which is also common. The pads should be able to move fairly freely. If not, remove the pads and shims and then grind away any rust in the notch where the shims sit on the bracket. Put caliper slide grease on this cleaned surface, NOT on top of the shim where it touches the pads. Reassemble, pump the brakes a few times, and check to make sure the wheels rotate freely.
Jay
Mike in PA
May 5, 2014 07:21 PM
jdap
Apr 24, 2009 05:16 PM
FordTruckNoob
21
Nov 30, 2008 05:52 AM
unclerusty1
1983 - 2012 Ranger & B-Series
Oct 6, 2006 08:55 AM
c96drumm
18
Sep 13, 2003 01:17 PM
