Brakes pulling to side
Old Jun 21, 2003 | 06:38 PM
c96drumm's Avatar
c96drumm
Angry Brakes pulling to side
I have a 89 E-150 that has a recurring problem with the brakes pulling to the side. I have done the following:
Bled brakes numerous times.
Replaced calipers, pads, rotors, front hoses, wheel bearings, tires, rear wheel cylinders.
Adjusted rear brakes several times.
When I first start to drive, it brakes straight 3 or 4 times, then pulls to the left when brakes are applied after that.
The pulling went away for a couple of weeks after replacing pads and rotors, then came back with a vengeance.
Since it takes 3 or 4 stops for this to start, I don't think it's related to steering, suspension or alignment, all of which is in pretty good shape anyway.
Any suggestions, no matter how farfetched, would be welcome!
Old Jun 21, 2003 | 07:43 PM
92 Red F150's Avatar
92 Red F150
c96, I just finished redoing the front brakes on my '92. I had similar issues as you when I bought this truck so hense the new brake job. I put on new rotors, calipers, pads, hoses,repack the bearings etc. When I pulled the old calipers off, the caliper support pins (those stainless steel diamond shaped caliper locating pins) were corroded and not letting the caliper float and caused the truck to pull. The bottom pin was even bent. The inside face of the rotor was wore big time. My new calipers came with new caliper support pins. What I did was lightly lube the new pins and grooves (and any other contact points) with Raybestos brake lube (just a skin coat, don't want any on the pads or rotor) and reassembled. The truck brakes like a dream now. Hopefully your 89 is similar to mine. Just something to check. P.S. Wasn't replacing that driver's side brake hose a treat? Hopefully the engineer who designed that is pushing a broom at GM! Later, Charles
Old Jun 21, 2003 | 09:53 PM
steve83's Avatar
steve83
It's most likely in the rear brakes since they're more mechanical and less reliable. What have done when you "Adjusted rear brakes several times"? When you pull the drums off, is either of the autoadjuster cables slack?
Old Jun 22, 2003 | 12:13 AM
c96drumm's Avatar
c96drumm
Yeah, Red, I did the same as you, new pins, lightly lubricated. Worked great for a few hundred miles, don't think there's a problem there, it's something else, but thanks for the reply! BTW, I think all engineers should be required to work as mechanics for 5 years before working as engineers. Maybe these things would be a bit easier to maintain.
Steve, the adjuster cables have never been slack. What I did today was tighten up the adjustment on the right rear shoes to see if that would affect the pull to the left. No change. I wonder if I've got a whole new problem, contaminated rotors/pads or something. Been doing my own brakes for 25 years, never seen anything like this.
Old Jun 29, 2003 | 02:50 AM
c96drumm's Avatar
c96drumm
Since last post:
Cleaned rotors/pads-no change
Replaced drums/shoes in rear- no change
Replaced right front caliper again- no change
Mental stability...slipping....away....please...help..... .
Old Jun 29, 2003 | 07:28 AM
TwoF150's Avatar
TwoF150
Crimped brake line restricting flow?
Old Jun 30, 2003 | 02:09 AM
c96drumm's Avatar
c96drumm
Good call, I checked, no restriction. Thanks for the idea!
Old Jun 30, 2003 | 07:45 AM
mr.tiny3's Avatar
mr.tiny3
I have had a simular issue with another vehicle. A VW Golf, I know it is not a Truck, Sorry.
The problem came from the master Cyclender. I had a valve sticking internally.
Have the MC checked or replaced
Old Jun 30, 2003 | 08:55 AM
luke_trash's Avatar
luke_trash
Is the proportioning valve set up in a way with these vehicles, that one side might possibly get more force than the other?
(i'm not terribly familiar with the system yet)
Old Jul 1, 2003 | 01:04 PM
c96drumm's Avatar
c96drumm
Thanks for the input, guys. The master cylinder output is one line to the front brakes and one to the rear, so there is no possibility of a side to side hydraulic imbalance involving the MC.
Old Jul 1, 2003 | 09:34 PM
pfogle's Avatar
pfogle
I would pull the whole assembly apart and anit-sieze the pins, it will last a whole lot longer that any other type of grease, do this every time you take it apart even if you just replace the pads and don't touch the rotors, I have a pulling problem in my 92 van it is just because I didn't follow my dads advice which I just gave you.....
Old Jul 5, 2003 | 12:42 PM
c96drumm's Avatar
c96drumm
Yessir, I have been lubricating the pins.
Now an interesting thing happened this morning. I switched the pads across to see if the pull would follow the pads. What happened is, the truck stopped straight for the first couple of stops, as usual. Then the next couple of stops it pulled right a bit. (pulling left is the problem) Then it went straight again a couple of times. Then it settled back into the old familiar left pull. Wierd.
Old Jul 5, 2003 | 08:17 PM
TwoF150's Avatar
TwoF150
Could one of the calipers be bad? Raise the front wheels off the ground apply the brakes and release. See if both wheels spin freely or if one does not release.
Clean the pads/rotors with brake cleaner to remove any grease or other material that can be on either.
Old Sep 12, 2003 | 10:40 PM
smpaul22's Avatar
smpaul22
have you fixed your brake pulling problem? i have it now on a 2002 f350
Old Sep 13, 2003 | 08:33 AM
c96drumm's Avatar
c96drumm
Not yet. It's been on the back burner due to fishing season, things like that, but I'm back into it and hopefully will have some useful info within the next few days. Will post.
Have you checked all that stuff suggested to me in this thread? The most common thing to cause this is a hanging caliper. I'd go after that first.
