what size backspacing for 16 x 8 rim and 245/65/16 tires
Old Oct 9, 2011 | 09:08 AM
IowanStraight6's Avatar
IowanStraight6
Well title says it I've search and search with no results so here I am I want to run 245/75/16 tires should be about a 30.5 inch tall so is a 16x8 rim the right width and what backspacing do I need for no rub I want them tucked under to the factory look thanks guys
Old Oct 9, 2011 | 09:29 AM
Conanski's Avatar
Conanski
The factory 8" wheel(mostly found on Broncos but also appeared on some F150 packages) has 4" backspacing(zero offset) and while it doesn't stick out past the fender any it fills the wheel opening a little better than the more common 7.5" wheel.
Old Oct 9, 2011 | 09:41 AM
IowanStraight6
So you feel the four inch offset will probably not have any tire rub lock to lock
Orange84
Jun 16, 2013 04:57 PM
MI79250
Dec 13, 2011 08:19 PM
murph_murphy
1978 - 1996 Big Bronco
Dec 14, 2010 04:27 PM
Outcastz89
May 13, 2008 04:50 PM
Galveston Yankee
Offroad & 4x4
15
Mar 29, 2008 12:48 PM
