Third brake light wiring for canopy
Old Oct 9, 2011 | 05:43 AM
montyrobison's Avatar
montyrobison
Hi all,
I have a 1995 F-350 PSD. I have purchased a canopy for it that has a third brake light. Is there an easy way to wire in the third brake light without a logic circuit converter, etc.? I've read that some newer F series already have a spare wire in the rear harness for this purpose. How about a 1995? Thanks in advance for your help with this.
Monty
Old Oct 12, 2011 | 03:41 AM
ILLXJ's Avatar
ILLXJ
I would just splice into the brake light wires & run them up through the stake pocket to the HMSL. Put spade connectors right inside the bed so if you want to take the top of you can unplug the light.
JIM.
Old Oct 12, 2011 | 05:16 AM
montyrobison
Jim,
Thanks for your reply. The problem with just splicing into the brake light wire is that this model year, and I think all ford F series for many years, uses the same lamp for the brake light and the turn signal. If you splice into the brake light / turn signal wire then the third brake light flashes when the turn signal is on.
Monty
Old Oct 12, 2011 | 06:20 AM
ILLXJ's Avatar
ILLXJ
That's right. At one time mine had a topper with the HMSL, it was wired up under the hood. Mine is a F-150, but it shouldn't be much different, I'll get a pic. of where it was wired into.
JIM.
Old Oct 12, 2011 | 07:48 AM
Flatbedbill's Avatar
Flatbedbill
The wires for the HMSL on the back of the cab run up the Ls B pillar. You can also splice in there.
dbarracuda
Jun 22, 2022 12:30 PM
69monster
Apr 22, 2010 12:51 PM
Clint40
Oct 11, 2007 11:35 AM
jvidul
1983 - 2012 Ranger & B-Series
Aug 12, 2003 10:41 PM
