Sandblasting my frame without removing the brake lines.
Old Apr 8, 2003 | 10:07 AM
Ken2600's Avatar
Ken2600
Can I safely blast my frame without removing my brake lines? Is there something I can cover them with or tape them with and just blast around them?
I know it would be a better job if I removed them but I'm just trying to figure out my options.
Old Apr 13, 2003 | 01:05 PM
Rosati's Avatar
Rosati
I wouldn't risk it. One small grain of sand stuck in a wheel cylinder...
An ounce of prevention, etc, etc.
Old Apr 13, 2003 | 09:18 PM
Ken2600's Avatar
Ken2600
Good point about prevention. I'm afraid that if I remove them, I'll have to replace them because they're getting old. I guess maybe that means I should replace them anyway.
Here's a related question. What about blasting a steel wheel without removing the tire?
Old Apr 13, 2003 | 10:20 PM
Carlene's Avatar
Carlene
Admom
Ken -
As long as your careful in removing the break lines and you haven't had any problems with them, I don't see why you'd have to replace them. We removed the lines from the '86 Mustang doner and put them in the '41 with no breakage or problems. Patience is the key.
As for blasting the rims with the tires on, shouldn't be a problem. What I did was used masking tape to tape off the rubber and used my fingernail to tuck it a little behind where the rim/tire meet.
Old Apr 14, 2003 | 09:14 AM
Ken2600's Avatar
Ken2600
Thanks Carlene. Maybe I'll give it a try then. They're on my old 77 and I'm not sure how rusted/corroded everything is going to be though.
Good news on the tire/wheel blasting too.
Thanks.
79xlch
1947 and Older Ford Trucks
71
Aug 13, 2022 06:57 PM
56exp
May 24, 2017 07:09 AM
Jsek
Jan 9, 2017 08:55 PM
Dvorocks
May 15, 2016 08:16 PM
GoldCo
All Things Towing
May 4, 2016 06:58 AM
