Fuel High Pressure Gage
Old Oct 2, 2011 | 12:06 PM
Emel's Avatar
Emel
I am looking for any information that i can install high pressure fuel gauge to monitor the fuel system for reduction in pressure,where to install the pressure transmitter,and what is the fuel pressure should be normal & minimum range on the 6.7 engine? Thanks, Emel
Old Oct 2, 2011 | 04:11 PM
sledhead_24_7's Avatar
sledhead_24_7
My Dash Daq from Spartan monitors the high pressure fuel rail. I don't know if you could find a gauge that reads 30,000 psi or not.
I have seen from 3000ish psi up to 29,000 something it just depends on how you are driving. Once up to 55-60 mph it seems to average around the 10-13,000 psi range.
Hope this helps some
Old Oct 2, 2011 | 11:05 PM
amikay12's Avatar
amikay12
Fuel pressure gauge
I installed a stewart warner mechanical pressure gauge, tapped into the line coming out of fuel filter going to the high pressure pump-- 0 to 100 psi gauge to make sure filters were not holding pressure down. My pressure runs about 75psi.. Mounted gauge in the cab. Also mounted oil pressure mechanical gauge in cab and exhaust temperature gauge
Old Oct 3, 2011 | 08:31 AM
darren32's Avatar
darren32
H&S Black Maxx is the same.
I would not tap into the HP side.......Ford already has something there to read pressure, just need to access it.
Thanks
Old Oct 3, 2011 | 08:34 AM
Tom's Avatar
Tom
Thanks
Completely agree with Darren. Attempting to tap the high pressure side is risking a spectacular failure...29,000 PSI is a LOT of pressure. The only feasible way is to read the values from the OBDII port.
Any particular reason you want to monitor these?
Old Oct 3, 2011 | 06:37 PM
sledhead_24_7
I lied on the lower psi it is 4500- 4800ish at a idle.
Old Oct 3, 2011 | 06:40 PM
sledhead_24_7
The reason for monitoring is to see if your fuel rail is losing fuel/ pressure. Not a big deal while stock, but running tunes it is nice to see.
Some of the bigger hp tunes can drain the fuel rail as the factory lift pump may not keep up with flow sometimes. if that happens you lose performance etc.
Old Oct 3, 2011 | 06:54 PM
Tom's Avatar
Tom
Makes sense, thanks for the explanation!
Old Oct 4, 2011 | 09:08 PM
Emel's Avatar
Emel
What do I need to read the OBDII port on the dash? I like the pressure gauge out of the fuel filter.Two of the older diesels had engine problems,with low furl pressure.Being a A&P I like gauges to keep truck of things.I'm trying to set this truck up to pull my hanger trailer to the air shows around the country when I retire from Beech Aircraft.Thanks fellows for all the information and help that I found on this site..I Love this Truck! Thanks Emel
Old Oct 5, 2011 | 06:43 PM
darren32's Avatar
darren32
This may do it, I am not sure. You should definately check with them before buying, I am not sure exactly what you can see with it.
They may also have something truck specific????
Edge Products| Product
Thanks
Old Oct 5, 2011 | 07:46 PM
Emel's Avatar
Emel
Thanks this will HELP Emel
Old Oct 5, 2011 | 07:59 PM
720Deere's Avatar
720Deere
I just ordered a CTS and it is supposed to be here Friday. I guess I will find out then if it reads rail pressure. I'm pretty sure I've seen others comment that it does.
Old Oct 5, 2011 | 09:49 PM
kper05's Avatar
kper05
I forgot to check my CTS today.
This is what Edge says it monitors.
Ambient Air Temp, Accel Pedal Position, Barometric Pressure, Battery Voltage, Corrected Speed, Dist. Between Regens, Dist. Since DTC Clear, Dist. Since Regen, DPF Pressure, DPF Soot Mass, DTC Count, EGT Post DPF, EGT Pre DPF, EGT Post Turbo, EGT Post SCR/Pre DPF, Engine Coolant Temp, Engine Load, Engine Oil Temp, Engine RPM, Engine Run Time, Fuel Level, Fuel Rate, Gear with Reverse, Gear with TCL, Intake Air Temp, Manifold Abs Pressure, Mileage Coach, MPG Instant, MPG Average, Nox PPM, Regeneration Status, Reductant (Urea) Level, Time 0-60, Time 1/4 mile, Torque, Torque Solenoid Pressure, Trans Temp, Turbo Boost
Old Oct 6, 2011 | 08:29 AM
darren32's Avatar
darren32
Sorry Emel, it appears that the CTS does not display the fuel pressure you are looking for.
Thanks
Old Oct 6, 2011 | 12:15 PM
720Deere's Avatar
720Deere
I'm going to check into it for the 6.7, but I know Power Hungry Performance can write new PIDs for the previous diesels. I have seen Bill do this numerous times on other forums, but I have not seen it done for the 6.7 yet. This may just be because the CTS official 6.7 support just began recently.
1994F2507.3L
Oct 14, 2016 03:58 PM
johnarahill
Jan 24, 2012 09:56 PM
gmc28
Nov 18, 2010 08:09 AM
WMDPSD
Aug 30, 2010 07:07 PM
brian42
13
Oct 9, 2007 10:27 AM
