will a gauge for hydraulic psi work if I am going to do the fpr shim. I just think that I need more fuel under wot, but I want to see what pressure I have before I start(at Idle). I don't think they make a specialized gauge for fuel do they?
Depends on the prussure range of the gauge. Most use a 0-100 psi. scale it gives more accuate reading say 1 or 2 psi. increments. Verses if it was a 0-500 psi gauge the increments are most likely 5 psi. increments. Which it could be off by 5 psi. reading. Hope this helps.
Yes 0-120 will work and yes liquid filled caseing is whats normally used because of the pressure spikes. If your just testing and not leaving ti on for ever or just a short time anything will work.
when I checked out guzzles site for the fitting for the fuel pressure gauge I see that there are 2 fittings, A 1/8 inch and a 1/4 inch fitting, which one do I want if I would like post filter?
