1995 F150 door adjustments??
Old Sep 29, 2011 | 12:26 PM
nottelybill's Avatar
nottelybill
Question 1995 F150 door adjustments??
both of my doors are loose and door will not shut tight. How do I adjust them?? 1995 F150
Old Sep 29, 2011 | 01:32 PM
tanz45's Avatar
tanz45
More than likely your striker bolts on the jam are worn out. (look for deep grooving and loss of material). This is mainly caused by worn out hinge bushings.
Just R&R it.
Old Sep 29, 2011 | 02:09 PM
nottelybill
there was a piece of plastic around them. I found a piece stuck to the bottom of the bolt. I assume if I buy 2 new ones it may fix the problem although probably not a long term fix.
Old Sep 29, 2011 | 02:36 PM
Elderstarr's Avatar
Elderstarr
Nope. Wont fix the problem.
X2 on the hinge bushings.
Old Sep 29, 2011 | 03:17 PM
White 97 xlt's Avatar
White 97 xlt
The complete repair will most likely be hinge bushings (if they move at all when you lift up on an open door), and the strike bolts replaced and adjusted properly after the hinges are done so the door is not flopping around.
Stevaroo01
17
Oct 13, 2017 10:31 AM
namxas
Dec 11, 2014 07:24 PM
JoeVR5
17
Feb 16, 2010 08:57 PM
doosky2k
Appearance & Dress-Up
Dec 20, 2005 05:44 PM
roadman
Nov 5, 2001 06:48 PM
