Go Back  Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
Reload this Page >
Door sags and isn't aligned with the striker
Old 05-29-2005, 10:24 AM
doosky2k
doosky2k is offline
doosky2k is starting off with a positive reputation.
What do I need to replace to fix my door, the only way I can close it is by lifting it as it closes.
Old 05-30-2005, 08:50 AM
plugugly
plugugly is offline
plugugly is starting off with a positive reputation.
sometimes the bushings and hinge bolts wear to cause a droop. They are a cheap fix from most auto parts stores to get new pins and the plastic bushings (2 for each hings) to replace them. Open the door and lift it up and down to see if the that is the area of problem.
Old 05-30-2005, 03:13 PM
trike1946's Avatar
trike1946
trike1946 is offline
trike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud of
Bushings wear and the door drops. Fairly easy to fix. If you don't have time to go find them you might try and put a washer between the bottom hinge and the frame at each mounting bolt. It might be enough to make it close. If it is a lot, try two washers at each bolt. Mark the hinge location before you move things around. Loosen both bolts but just remove them one at a time so you don't have to steady the door so much. Put a screw driver behind the hinge, and pull one bolt, slide in the washer and start the bolt in but not tight. Then do the other bolt and then tighten them both in the marked location. Then you can get the bushings when you can. Good luck with it.
Old 12-20-2005, 05:44 PM
spidk43
spidk43 is offline
spidk43 is starting off with a positive reputation.
http://www.lincolnsonline.com/article45.html
Here's a guy who showed pix and detailed instructions on how to fix his. I looked up the parts online and the new pin/bushings cost $4.98 or something at autovalue (for years 87 to 96 I think) and the part number is 38410.
Same problem on my truck, but from people trying to slam the door shut, the striker basically broke. That part # is 38448 and it cost around $8.00
~Matt
quincyj34
18
04-10-2014 07:10 AM
steveamann
10-07-2012 07:42 AM
Luddle
05-14-2008 10:47 AM
neilc88
12-08-2007 11:55 PM
MemOrex
11-22-2004 01:24 AM
Quick Reply: Door sags and isn't aligned with the striker
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
