C6 Transmission 1987
Old Sep 17, 2011 | 10:30 PM
PAULAU123's Avatar
PAULAU123
Hi there!
My motorhome, a 1987 Ford E350 econoline 351W 5.8L has a transmission that slips in reverse. Is there anything I can do to try and fix it myself ? I found another trany it's out of a Ford also but has an overdrive. Would that be suitable for my motorhome ? Hope to hear from someone soon. Thanks
Old Sep 17, 2011 | 11:26 PM
Kemicalburns's Avatar
Kemicalburns
the tranny with an overdrive doesnt sound like a C6. it sounds like an E4OD which wont work with out extensive wiring changes.
have you serviced your C6? how many miles on the tranny? luckily the C6 is probably the cheapest to have rebuilt and you can get a tuff well built unit for well under $1000.
Old Sep 18, 2011 | 09:06 PM
PAULAU123's Avatar
PAULAU123
Thanks for the reply. It only has 115500 miles on it but it was hit in the right front causing propably this problem. I'll take it off and have a look inside. Do you think that this is wise? Do you have any advise? Talk soon
Old Sep 19, 2011 | 04:03 PM
Kemicalburns
the C6 is pretty simple tranny. hard to say if the impact caused your current tranny issues. the vacum modulator controls the shifting of the tranny so if there are any vacum leaks going to that device it could cause it to act up.
Old Sep 20, 2011 | 07:33 AM
PAULAU123's Avatar
PAULAU123
HI THERE! THANKS FOR THE REPLY. THE MODULATOR VALVE HAS BEEN CHANGED AND THE MOTOR IS RUNNING FINE NOW BUT THE TRANNY IS NOT RESPONDING I GUESS I'LL HAVE TO GET IT FIXED OR BUY ANOTHER ONE. I WAS THINKING OF TAKING IT OFF THE MOTORHOME AND TAKING A LOOK INSIDE. ANY ADVICE?
Old Sep 20, 2011 | 04:05 PM
Kemicalburns
by all means drop the pan and take a look. pay attention to how the fluid looks and if any debri is present
Old Sep 20, 2011 | 09:26 PM
PAULAU123's Avatar
PAULAU123
thanks for the reply oil is smelly and dark and have debri in it I guess I'll have to find a new one..Thanks for the advice
brthevio
Mar 22, 2009 11:33 PM
Fordman1983F100
Oct 28, 2007 01:30 PM
Coolarctic
Feb 12, 2007 11:55 PM
weldingfreak
Iowa Chapter
16
Mar 18, 2006 08:17 AM
oricle
Oct 24, 2004 12:52 AM
