Fuel in motor oil!
Old Sep 16, 2011 | 06:09 AM
Roelito78's Avatar
Roelito78
Fuel in motor oil!
Hello fellow Gurus,
This past week I replaced the rear main seal on my 79 f 150 351m. As I took my oil pan out I noticed the smell of fuel in the oil. The oil had a heavy mixture of fuel in it. I have been experiencing starting issues the past couple weeks to the point of full battery drains just trying to start it. The first thing that came to mind was to check my carb. As I open it up the carb was bone dry in regards to fuel. Could this be the root cause? Any other ideas? Thanks
Old Sep 16, 2011 | 07:16 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Carb dry, fuel in oil=busted diaphram in fuel pump.
Old Sep 16, 2011 | 07:35 AM
Roelito78's Avatar
Roelito78
GFW,
Shouldnt the carb hold fuel? When I pulled the carb out i did see fuel inside the motor through the manifold. This leads me to believe that fuel is getting up to the carb. Will a fuel pump with a bad diaphram still pump fuel up to the carb? Thanks
Old Sep 16, 2011 | 07:45 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Depending on how bad the hole in diaphgram is, yes it will still pump fuel to carb. Fuel should stay in carb till it eventually evaporates. If it doesn't, fuel could be leaking out into intake, cylinders and into oil. My first post was based on no fuel, dry carb.
Old Sep 16, 2011 | 07:47 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by Roelito78
GFW,
Yes, it will but just barely. The majority of the fuel it's pumping is going into the crankcase.
The fuel pump has "weep holes" engineered into it's design to help avoid this but over the years these can clog up forcing the fuel to go into the crankcase.
Replace your fuel pump and the oil dillution will go away and the hard starting should go away too.
Old Sep 16, 2011 | 07:50 AM
Roelito78's Avatar
Roelito78
GFW,
I believe that fuel is leaking into the intake from the carb. I could be wrong but like I mentioned, inside the intake manifold there were traces of fuel. I soaked 2 or 3 shop rags when i stuck them inside the intake. Could the float be bad on the carb? Should I change the fuel pump just in case?
Old Sep 16, 2011 | 07:56 AM
Roelito78's Avatar
Roelito78
Mike,
So, it seems like the culprit might be the fuel pump. My dad is rebuilding my carb today. He seems to think that the fuel is leaking through the carb into the motor. Maybe we have it wrong.
Old Sep 16, 2011 | 08:04 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Float stuck open and continualy cranking will force fuel into intake(flooding). Depending on carb, and I don't know the internal workings of all, there could be a hairline crack in it allowing bowl to empty in to manifold. You could test fuel pressure from pump and get some idea on it's condition. Should have 4-6psi. You obviously have carb off, so good time to rebuild it and check fuel pressure. Carb will put gas into oil, but usually the problem is fuel pump.
Old Sep 16, 2011 | 08:07 AM
Roelito78's Avatar
Roelito78
Thanks GFW and Mike! Fuel pumps are inexpensive so I might change it out and rebuild the carb. Hopefully the problem gets resolved! By the way carb is a motorcraft 2 barrel.
Old Sep 16, 2011 | 08:09 AM
Roelito78's Avatar
Roelito78
One more thing, I did try to start the truck many times the past two weeks. I ran the battery down 3 times. Thats probably why so much fuel was in the oil
Old Sep 16, 2011 | 12:34 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Sounds like a plan and that your Dad knows what he's doing.
Old Sep 16, 2011 | 12:47 PM
Roelito78's Avatar
Roelito78
Lol! He is not a guru like you guys but he has rebuilt several carbs in the past.
Old Sep 16, 2011 | 01:01 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Post count has nothing to do with actual knowledge. Rep points mean more than anything else. At least that means someone found their info useful.
Old Sep 16, 2011 | 01:13 PM
raytasch's Avatar
raytasch
Believe Nothing
If folks understand how this works and will act.
Old Sep 16, 2011 | 01:14 PM
Roelito78's Avatar
Roelito78
You guys deserve a lot of credit! Its a good thing to be able to go online to these forums and obtain valuable info.
