04 f-250 all stock
Old Aug 21, 2011 | 05:32 PM
jerry64's Avatar
jerry64
04 f-250 all stock
wont build any oil presure at all low or high
Old Aug 21, 2011 | 05:53 PM
jerry64's Avatar
jerry64
any help would be great
Old Aug 21, 2011 | 06:00 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Well maintained? Recent work or oil change? LPO's got to be there to get HPO. No pressure @ gauge or filter housing?
Old Aug 21, 2011 | 06:07 PM
brickie's Avatar
brickie
Pull the lpo pump,hopefully it didn't eat a lifter bearing.Could also be a huge hpo leak.
Old Aug 21, 2011 | 06:14 PM
bismic's Avatar
bismic
A couple of easy things to check:
wrong oil filter and the filter drain valve is open
LPOP regulator stuck open
Old Aug 21, 2011 | 06:19 PM
brickie's Avatar
brickie
Oooh. Never thought about the oil filter Mark,and the regulator is also a valid cause to the issue.Rep ya later
Old Aug 21, 2011 | 06:21 PM
jerry64's Avatar
jerry64
new to diesels truck was ideling just died wont restart no code ford tech said needs motor wont pump to filter tech held something down and stil no oil
Old Aug 21, 2011 | 06:24 PM
jerry64's Avatar
jerry64
tech also said piece of metal in something with a screen under truck
Old Aug 21, 2011 | 06:26 PM
brickie's Avatar
brickie
Sounds to me like your lpo pump ate something other than oil.
Old Aug 21, 2011 | 06:28 PM
jerry64's Avatar
jerry64
just bought this truck a month ago dont no what to do with it motor or scrap
Old Aug 21, 2011 | 06:29 PM
Snuggyworm's Avatar
Snuggyworm
yep. i agree wif brickie. sounds like an oil screen.
Old Aug 21, 2011 | 06:31 PM
jerry64's Avatar
jerry64
is this fixable or motor
Old Aug 21, 2011 | 07:17 PM
Rusty Axlerod
At least a partial tear down. Pump could be replaced but problem is where did metal come from?
Old Aug 21, 2011 | 07:26 PM
bismic's Avatar
bismic
If it is a month old, pursue action to get re-imbursed from seller!
Old Aug 21, 2011 | 08:37 PM
Piolet's Avatar
Piolet
I would say it's critical that the metal part that was found be identified. Hopefully the tech that found it didn't just toss it in the trash.
This This is a link to powerstrokehelp.com where Bill describes a lifter head doing a bunch of damage (disclaimer: I know a lot don't like Bill, I have zero opinion on the guy, just posting the vid for illustration).
Some other part might have broken that's not as catastrophic to repair.
Or, if a part was left inside the engine after some work was done maybe you'd have some recourse (maybe like a small screw or washer or something that wasn't noticed).
I think you need to identify that piece to make a good decision on what to do next. Best of luck. I hope it all works out good for you to be sure!!
