I'm wanting to add OEM fog lights to my 2005 F-150 its not wired for fog lights. I was going to get a new front bumper because someone backed into me. If i get the OEM swich for fog lights do I need to get a wire harness? If so where can i get it for a good price?
Hello brandhill910,
I believe that you will need to buy a fog light wiring harness if you purchase the switch. fordpartsgiant.com sells the wiring assembly for the fogs for about $19, if I remember correctly.
According to my factory wiring manual;
The main harness has the fog light wiring from the factory.
The connectors should be in place behind the bumper on both the left and right sides.
The switch may need to be changed out.
Try to gently pull the switch **** outwards to see if it clicks into the fog light position.
