Sponsored by: Auxito
Can't turn the heat down
Old Jul 22, 2011 | 06:25 PM
MacDug's Avatar
MacDug
1998 ford F-150 XL 4.2L engine... One day I couldn't turn down the heat, I get heat from the blower in all temperature setting on the climate control. When on AC the compressor engages normally, though I haven't checked my AC coolant, if it was that then I should at least get cool outside air on the "panel" setting. Not sure how to work this,, and Ideas?
Old Jul 22, 2011 | 07:17 PM
projectSHO89's Avatar
projectSHO89
Read the FAQs in the HVAC section. Your answer (or at least, guidance) is there.
Old Jul 23, 2011 | 08:35 AM
steve(ill)'s Avatar
steve(ill)
there is an electric motor operated "blend door" tht mixes hot and cool air to get the expected temp. Your motor, or cam / gearbox to the door is broken. I think its located under the radio, above the transmissiosn hump, more to drivers side. Take off the plastic cover to see, then operate the temp ****.
Old Jul 25, 2011 | 07:42 PM
MacDug's Avatar
MacDug
THANKS i'll pull the radio and check it out
Smokeyseventhree
Jan 11, 2015 08:11 PM
scooterspal
Feb 9, 2012 07:50 AM
MacDug
1997 - 2003 F150
Jun 2, 2010 09:00 PM
claycomotrucks1991
22
May 29, 2009 11:02 AM
claycomotrucks1991
May 27, 2009 07:04 PM
