re-installing transmission 95 Ranger
Old Jul 7, 2011 | 09:26 PM
dbwright15's Avatar
dbwright15
how does one re-install the manual transmission. We're trying to line the spline up with the clutch and it just doesnt want to line up... is there a trick to this??
Old Jul 7, 2011 | 10:15 PM
Rangerman Stan's Avatar
Rangerman Stan
Welcome to FTE. Did you test fit the clutch disc to the transmission to make sure it fit before you installed it? Also if you replaced the clutch assembly, did you use an alignment tool for the clutch when you installed it to the flyweel? It helps a lot to use one of these tools. If the transmission shaft splines won't line up with the splines in the disc then try rotating the input shaft slightly one direction or the other to help them line up and go together. Once it starts to go in you may need to raise the back end of the trans to help it be aligned better to go all the way in. If it's not aligned really well it won't go all the way.
1999_Super_Doody
6.7L Power Stroke Diesel
Mar 8, 2017 03:59 PM
tired-n-dusty
Aug 28, 2014 09:33 PM
dstraw
30
Jul 26, 2014 09:11 AM
Dutch123
1978 - 1996 Big Bronco
26
Jul 21, 2010 07:48 AM
Kwikkordead
31
Jan 16, 2007 10:24 AM
