Thinking of replacing T-stat or Housing? Read this
Today I flushed my coolant and installed my DieselSite coolant filter. But I also had to replaced my waterpump
I was in the process of taking out the thermostat the three 6X1.0 bolts for the thermostat housing either busted or stripped out (stipped)due to the 1/4" drive deepwell craftsman socket cracking). This happens because the person before failed to put antiseize on the threads before installation. steel to aluminum dont mix. I considered taking the alt and PS bracket off, reaming and tapping bigger, but I did have shaft play so I just installed a new waterpump. Very easy to replace the waterpump. Hardest part was getting the fan threaded back on! (use a air chiesel to take it off)
Just a warning to anyone considering replacing just the tstat and dieselsite tstat housing, be prepared! Again, 6x1.0 metric bolts dont bother going to a supply store, just go to advanced auto or similar chain store and they will have a FLANGED bolt!
ElMoco
46
11-28-2016 09:42 PM
Ponyboychris
25
03-07-2011 07:21 AM
