Leaking T-Stat housing - Updated with Pics!
OK, so I thought I had a lower o-ring on my waterpump going out but it's the t-stat housing/seal that is leaking. I ordered the billet style from Bob at Dieselsite and will grab a OEM T-stat from the dealer this week. What is the final procedure to seal up the billet housing to the waterpump? I've read so much but I cannot understand the final answer. Thanks again everyone!
Stuff a rag in the neck, completely sealing it. Get a file and true up the mounting surface where the housing mounts. Vacuum all the particles out of the rag and remove the rag. RTV the housing, let it set up a little bit, then install it in your truck.
Or you can just RTV the housing and forget the filing part.
Stewart
Stewart
I use Right stuff gasket maker which is a rubber based gasket in a pressurized can. It works great, and can be put back into service immediately. Make sure you get the NEW Ford thermo which has an updated gasket with that is formed onto both sides of the thermostat. Makes the square cut gasket and leaks obsolete as the new design sandwiches the gasket on either side!
I consider myself lucky. Years ago when I did the water pump on my Ex and put on the billet housing, I did the even torque method and my housing doesn't leak.
I do need to take mine off though to swap in a stock thermo for the 203* degree I have in there now. When I do, I'll probably use RTV when I put it back together.
Stewart
on
I basicly did the same thing, but added a small amount of RTV on the w/p housing where the t-stat housing sits (none on the gasket). I have the 195* Motorcraft t-stat with the updated gasket.
This is the condition of my current housing. It's amazing that it still holds water under pressure. So black permatex and even torque is the best bet?
Yep, you'll be golden just make sure to just get it on the mating surfaces, around the ends not near the gaskets. I also let the truck sit overnite to cure so there was any coolant mixing up with the Permatex.....
