I have a 1998 Ford F800 comes with the cummins engine 5.9 with turbo.
Im gonna adjust the valves,but before i do i need the valves specs
Can some one help me out with the intake and exhaust "GAP" adjustment?
I sure will appreciate the help thank you in advance.
intake 0.254mm (.010in)
exhaust 0.508mm (.020in)
locate TDC with timing pin and adj
#1 int & exh
#2 int
#3 exh
#4 int
#5 exh
mark the pully, rotate crankshaft 360 degrees, adj
#2 exh
#3 int
#4 exh
#5 int
#6 int & exh
