Heater Core, '93 F150
Old Mar 19, 2003 | 01:08 PM
surveyor's Avatar
surveyor
I have a coolant leak I haven't been able to find (previous post).
I may have just found it, I smell antifreeze now in the cab. I see no signs of leakage (probably small) from the heater core area.
Anyone have experience in changing one of these puppies?
Is it difficult? What all is entailed?
First, I may try Prestone's Super Sealer, any thoughts?
Thanks !!
Old Mar 19, 2003 | 11:12 PM
steve83's Avatar
steve83
Don't waste the time & money on the sealer - just get a good replacement core. It's one of the easies things to change. Just pull the heater hoses at the firewall, the glove box, & then the large flat black plastic cover you see inside the dash. The core will almost fall out. Make sure you have the foam gaskets on the new one before you put it in.
Old Mar 20, 2003 | 08:23 AM
surveyor's Avatar
surveyor
Thanks Steve, I checked it out, noticed no leaks. I think I'll have a pressure test done and hopefully the core or radiator will leak and I'll see it.
4x4 Bart
44
Mar 7, 2014 12:39 PM
RA31925
Mar 5, 2013 08:28 PM
JasonBrod
1997 - 2003 F150
Oct 4, 2012 02:05 PM
f150rd
Dec 19, 2011 07:55 AM
waggondragger6213
Nov 1, 2009 04:11 PM
