92 f150 codes
Old Apr 4, 2011 | 09:31 AM
ctruf1504x4's Avatar
ctruf1504x4
92 f150 codes
I did a KOEO test and I got an 11, what would case this. I also got a 31 33 and 34 I think that the sensor on the egr valve is bad but dont know.
Old Apr 4, 2011 | 10:41 AM
rla2005's Avatar
rla2005
That code 11 is not really a code, that is a System Pass.
The other codes 31 and 34 are related to the EVP signal when the EGR is supposed to be closed. Code 33 indicates the PCM is not sensing any EGR movement at all.
I would start by checking the EVP output signal. See what it is with the valve closed, then apply some vacuum to the EGR and watch the output signal.Verify if it jumps around a lot. That indicates the EVP sensor is probably faulty.
As far as Code 33, check the EVR it may be bad or someone has disconnected the vacuum source to the EGR valve circuit.
For reference:
Ford Fuel Injection » EGR Valve Position sensor (EVP)
Ford Fuel Injection » EGR Vacuum Regulator (EVR)
Old Apr 4, 2011 | 12:00 PM
fastpakr's Avatar
fastpakr
The 31,33,34 are also memory codes in this case. Since you're passing KOEO, clear those and make sure you're passing KOER (I doubt it, in this case). Troubleshoot based on those tests until you get a pass code there, then worry about stored memory codes if they continue to pop up.
WhatsAChevy?
Dec 28, 2015 11:22 PM
Farmboypowerstroke
Oct 29, 2011 05:05 PM
LiftdFord
21
Aug 18, 2009 01:26 PM
1979 sidestep
Feb 5, 2008 11:35 PM
79-400-POWER
1978 - 1996 Big Bronco
29
Aug 6, 2007 04:22 PM
