engine loses fire
Old Apr 4, 2011 | 12:04 PM
p-willie's Avatar
p-willie
engine loses fire
need help with my 86 f-150 4x4. dies going down the road like youturn off the ignition.have replaced the follwing, complete distributer,(all new components) coil, ignition switch, ecm, inersha switch, relay under dash, truck will crank after a few minutes, or when i pull the coil wire off to check for spark. pleas help if you can, p-willie
