By pass filters
![Question](images/icons/icon5.gif)
I've got an amsoil bypass kit installed but would like to know if anyone has found an alternate filter to theirs. The $30 a pop bypass filter get expensive when added to the oil change costs.
I know some of the other kits have screw on filters so does anyone know if they are cheaper and will fit?
Thanks Hank
Thanks Hank
yes thats what amsoil advertises, but last check at 7000 they told me to change about 10k, and with all the data from here that is about the max to keep the oil from breaking down.
I changed at about 8K and it sure quieted down a lot with clean oil, the bypass just keeps it a little cleaner longer.
Texas I considered that but why keep almost 2 qts of dirty oil in when you change? Remember the old messages from way back when when folks would just add oil and keep the filters? Same thing IMO. No I will spend if I have to, but if I can get a suitable substitute cheaper then it will be to my advantage.
Coolant filters are to be changed regularly min of annually but they are inexpensive enough that they could be changed with the oil. I have my coolant system on now and will be changing everything with a flush and refill and probably within 1K after its done. The one site said to change after the 1st 500 miles on initial install so will hopefully have some good results with my planned changes of the coolant filter. Who really knows?
I have a drain petcock on my by pass filter canister. No reason to open it up everytime I change the oil.
I have an Amsoil setup and the beauty of the re-circ line is that the old oil in the bypass filter can be pushed out and captured from the oil-fill fitting...I did last week it it worked great....did the oil and oem filter change, then just ran the motor until I seen the honey color coming through and shut here down and topped off.
