2011 F250 crew 4x4 Question
Old Feb 23, 2011 | 01:53 PM
pundy's Avatar
pundy
Hellofficeffice" /><O></O>
I was wondering if there is a way to lower the rear of the truck about an inch without voiding the warranty or hurting the tow/hauling performance. The back of the cab of the truck is just a little too tall to get into my garage. Thanks in advance.<O></O>
Paul<O></O>
Old Feb 23, 2011 | 03:30 PM
Hu Slung Pu's Avatar
Hu Slung Pu
Old Feb 23, 2011 | 03:38 PM
reels's Avatar
reels
It might be easier to move the header of the opening up a bit. Get a case of beer and invite your local carpenter over.
Old Feb 23, 2011 | 03:39 PM
Marauder92V's Avatar
Marauder92V
1000 pounds of sand should do it! Seriously, I almost came to the same problem as you are having. My F350 clears my door by less than 1 inch. I don't think you can do anything "cheaply" to the suspension to get the clearance.
I am modifying the door because the clearance on top is too tight as well I need to tuck the mirrors to get it in. If the garage door is not a load bearing wall, modifying it is not a big issue that a contractor can do for you. Mine is load bearing and I need to put in another header to allow me to have the 10 foot wide door I want.
Old Feb 23, 2011 | 03:52 PM
pundy's Avatar
pundy
Thanks guys, I have the clearance on the garage door, I just have a steel beam that runs across the center of the garage. I put 800 pounds in it the other day and the front end came up a little. I still cleared but it was soooooo close. I would like to have a little wiggle room if i could. Just hate to have that thing sitting outside. Any other ideas? Thanks again.
Old Feb 23, 2011 | 04:02 PM
Marauder92V
What is a steel beam running across your garage for??!!
Old Feb 23, 2011 | 04:18 PM
pundy's Avatar
pundy
It is holding the house up I guess, its boxed in drywall but I took the bottom piece of drywall off and thought that would give me enough room but I still need a little more. Thanks
Old Feb 23, 2011 | 05:11 PM
cummins cowboy's Avatar
cummins cowboy
I would advice against it, the reason being the f250 already sits almost exactly level, there may be .5-1" more height in the back but thats it. you would be sagging the back with no load on the truck by doing that.
Old Feb 23, 2011 | 05:17 PM
BRUTUSIII's Avatar
BRUTUSIII
Your 250 has 2" blocks bolted in the rear axle. You could have custom 1" blocks made and buy some new Ubolts. It would only cost a few hundred $s.
Old Feb 24, 2011 | 11:04 AM
Scootimus's Avatar
Scootimus
Smaller rims and/or tires? When the factory rubber runs out you could always go with a slightly lower profile tire. No not the ones you see rolling around on the old impalas, just a slightly lower profile truck tire.
Old Feb 24, 2011 | 12:25 PM
96bigblueford's Avatar
96bigblueford
Could you back your truck in the garage?
JF_VIKINGSFAN
Dec 22, 2012 06:59 AM
retiredinstructor
Mar 20, 2012 05:30 PM
lakerats
Mar 17, 2011 02:40 PM
lakerats
Electrical Systems/Wiring
Dec 8, 2010 08:00 AM
lakerats
18
Oct 16, 2010 09:10 PM
