Tranny hemmoraging - top rear area help..
Old Dec 28, 2010 | 05:07 AM
Angelobim's Avatar
Angelobim
My old dog is leaving me stranded again. It a 99 F250 SD with the 7.3 4x4 automatic with 362,000 miles on it. Sure was trying to hit 400k this coming year, oh well. I really don't want to junk the truck but I just can't swing a 1600 dollar repair bill for it, I spent too much on it this year.
I pulled into driveway at night ok, went to leave in the morning and noticed a trail of oil following me out the drive. Pulled back up and looked under and saw a steady stream of trans fluid running down from the top of the tranny down and off of the drivers rear corner of the drain pan. When daylight came I tried to view the location of the leak with a camera and even a mirror after cleaning area first with brake clean, I can't believe I can't see the source as much as what is coming out. The only work that was done to the truck in the past week was I replaced both valve cover gaskets because of the wiring connectors. Trans was fine until I tried backing out of the drive, engine and trans were cold and under no load.
I'm not sure which trans I have, Ford can tell by vin right?
Thanks for any help or input.
Angelo
Old Dec 28, 2010 | 06:18 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Ford can look it up by the VIN. The only automatic that was in the 99 trucks was the 4R100.
Old Dec 28, 2010 | 04:59 PM
Angelobim's Avatar
Angelobim
Thanks, I did see what looks like a vent hose fastened to a top rib so I unclipped it and pulled the hose down to see if the leak was there, nope, hose is dry. I did see in a pic that there is an electrical connector on the tailshaft housing I believe but I figure if the leak was there, it would leak further back and not fill the 2 square recesses on the top of the trans before running down.
Any thoughts?
Thanks
Angelo
