Tank Fill Hose
Old Nov 25, 2010 | 09:58 PM
redman84's Avatar
redman84
Tank Fill Hose
Anybody know the inside diameter of the hose that connects the fill neck to the rear tank? I fixed my pickup tube and pulled out the small inner hose and metal ring from the filler neck but the larger, outer hose is cracked at the tank connection and leaking diesel.
Old Nov 26, 2010 | 04:46 PM
redman84's Avatar
redman84
bump....anybody?
Old Nov 26, 2010 | 04:56 PM
plgebbia's Avatar
plgebbia
I'll try to get you the info later tonight.
Old Nov 26, 2010 | 07:10 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
It should be 2" O.D.
maybe this helps a little
http://www.transferflow.com/Resource...20Brochure.pdf
Old Nov 26, 2010 | 07:14 PM
plgebbia's Avatar
plgebbia
2" O.D. should be right. I checked the neck on a tank I had at the shop.
Old Nov 28, 2010 | 10:13 AM
redman84's Avatar
redman84
Thanks guys. I gotta get me a new one. Is it just generic hose or does it need to have a certain rating?
Old Nov 28, 2010 | 11:16 AM
plgebbia's Avatar
plgebbia
It will need to be rated for diesel fuel minimally.
Old Nov 28, 2010 | 11:17 AM
Talyn's Avatar
Talyn
When you had that all out, did you do the hutch mod?
Old Nov 28, 2010 | 11:27 AM
redman84's Avatar
redman84
Ok. The reason I ask is because all the vent mod write ups I've seen say nothing about addressing the quality of the hose.
Old Nov 28, 2010 | 11:33 AM
redman84's Avatar
redman84
Not sure what the hutch mod is. If its the same as the vent or harpoon then not yet. I was just gonna do the pickup tube and decided to gut the fill neck while at it. I plan to vent it soon but for now it fills just like it always has except for the leaky crack.
Old Nov 29, 2010 | 11:05 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
I think because most use the OE hose, no a replacement as in your case.
Maybe this link is helpful for you.
Diesel Fuel Hoses at Amazon Hose and Rubber
hotrodfeguy
Aug 30, 2014 12:02 AM
teamlx88
Jun 15, 2014 07:48 PM
powersmoked
1983 - 2012 Ranger & B-Series
Jun 4, 2012 04:52 PM
wmodon
Aug 16, 2004 07:50 PM
