Hi. Can any one help. I would like to find a pair of Ford tow hooks I think the part number is C5TZ19B5379 these are used on 1965 and up on heavy duty trucks if my info. is correct. They where never available in Australia,The ones that I have seen on the net are more of a Rino horn shape than a hook shape. If any one could help would sure appreciate it. Brian.
Thanks for your reply. I want to use the Ford ones that I think where either dealer or factory I have used only original ford parts so far and would like to keep it that way. I have a 64 f600, it has two holes in the top flange of the chassis rails on each side which I hope would match up with the tow hooks. If you go to 61-66 f100 fourm and go back a couple of pages you will see my truck with a link to Australian 64 photos and you will see what I mean. thanks.
The part number (I gave it to you originally) is C5TZ-19B537-D / This part number did not come from the 1964/72 Ford truck parts catalog as there are no tow hooks listed for F600's until 1967.
I got the number from the 1965 & 1966 truck accessory brochures, and according to the brochures, these only fit 1965/66's, but I said they might work on later trucks.
