300 timing
Old Oct 26, 2010 | 08:06 AM
Blackwaterforge's Avatar
Blackwaterforge
300 timing
I have a 66 Ford F-250 with a 300 6 cyl, 4-speed and 4.10 gears.
I am having a hard time finding the correct timing so it doesn't ping going up hills. The truck runs strong has good compression (150 lb on all cylinders) and hold 50 lbs of oil pressure..
The engine is stock other than it has a Carter YF carburetor.
Old Oct 26, 2010 | 10:01 AM
parr4's Avatar
parr4
You did not post which ignition system it has but when I had this 'pinging' problem I determined it was being caused by the weak springs in the distributor. Anytime above idle the weak springs caused the vacuum advance to fully advance the timing. That problem can be fixed by tuning the distributor, if you can find a distributor machine somewhere. I could not, so I disconnected the vacuum and fooled with the initial timing set. Settled for 10dg initial timing. It's been running like that for almost 250K miles on mechanical advance only...regular gas. Pinging is only a memory.
Old Oct 26, 2010 | 03:40 PM
Blackwaterforge
It has a stock dizzy with points (Dwell is 40 degrees).
I will try unhooking the vacuum advance and setting the initial timing at 10 degrees.
Thank You!
Old Oct 26, 2010 | 04:28 PM
parr4's Avatar
parr4
Prolly won't work for you. My system is Duraspark2. The springs in your set-up should be correct, but tuning the distributor would most likely help.
Old Oct 26, 2010 | 05:58 PM
69 f-100 aman's Avatar
69 f-100 aman
I have a new dist and a pertronic ignitor(that mean there is no points or cond in the distributor) that I'll sell to you,I put a mallory distributor and coil on mine. Let me know if you are interested. Dan
Old Oct 26, 2010 | 08:40 PM
Harte3's Avatar
Harte3
Forget the arbitrary degree numbers and use a vacuum gauge to time it. Disconnect and plug the vac advance, hook a vacuum gauge to a full manifold vacuum source, turn the dizzy until the highest steady vacuum reading is found,back 1-2 hg from there. Adjust the idle mix and speed on the carburetor, reconnect the vac advance, drive and try. If it still pings, back off the dizzy 1 hg and try again. By using this method you will be adjusting the timing to what your engine likes.
Old Oct 27, 2010 | 12:58 AM
overlandexpress's Avatar
overlandexpress
I would also install electronic ignition instead of points, I installed the pertronix II with a new matching coil and it smoothed my truck right out. It was a noticeable differance and worth the money. If you go with the pertronix system use the Pertronix II as they upgraded it so the system won't burn out if you leave the key on accidently.
Old Oct 27, 2010 | 07:43 AM
Blackwaterforge
Thanks guys!
Will try the vacuum gauge method.
I am going to stick with the points for now.
1986F150six
Feb 13, 2015 10:59 AM
Blackwaterforge
Feb 2, 2012 04:34 PM
cobraguy
Nov 17, 2009 04:16 PM
dcs
Apr 15, 2002 10:52 PM
