Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1997 Ryder F 700
Old Oct 11, 2010 | 11:13 AM
whrvsc's Avatar
whrvsc
1997 Ryder F 700
I have a 1997 Ford F 700 with 460 Fuel Injection. It has no spark. The distributor looks like the one used with TFI module. Is the TFI used with Fuel Ijection? If so do you have any idea where the module is? Thanks,
Mike
Old Oct 28, 2010 | 05:41 AM
fordpower46's Avatar
fordpower46
I am not that familiar with the medium and heavy duty trucks but on pickups the tfi is usually located directly on the distributor or built into the ignition box. you will need a tamper proof torx bit to remove it.
Old Oct 28, 2010 | 08:02 AM
cj06's Avatar
cj06
i think the module is mounted on the drivers fender .
Old Oct 28, 2010 | 07:14 PM
jpr38057's Avatar
jpr38057
There is no such thing as a 460 in a big F series. I would be a 429.
Old Oct 28, 2010 | 11:20 PM
85e150's Avatar
85e150
You think Ryder would go 429 on rentals? High probability it's a 370....
OP should post the VIN.
Also, do the standard trace --find something hot, and keep following the trail till you find the break. Juice to the module, juice to the coil, juice to the ignition switch?
Old Oct 29, 2010 | 04:57 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by whrvsc
I have a 1997 Ford F 700 with 460 Fuel Injection. It has no spark. The distributor looks like the one used with TFI module. Is the TFI used with Fuel Injection? If so do you have any idea where the module is?
Welcome to FTE
Two different ignition modules are listed for your application.
5U2Z12A297B (replaced E8DZ12A297A) .. Remote Mounted TFI Ignition Module (Motorcraft DY1075).
F2PZ12A199AA .. Ignition Module-not TFI (Motorcraft DY683).
Both, according to the parts catalog are located on the left fender inner apron. The non TFI module is a (silver) rectangular box.
There were no 460 engines installed in anything larger than an F350. If there are 7 valve cover bolt holes per side, it's either a 370, or it's larger brother, the 429. Both look identical to a 460.
Post the VIN found on the Certification Label, or off the registration. Or if you want to keep it private, post just the 8th digit of the VIN which is the engine code.
Old Oct 29, 2010 | 10:33 AM
whrvsc's Avatar
whrvsc
Thanks for the responses. You all are right, it is a 429. I finally found a Ford service manual for it. It turns out the ignition module is mounted in a recess in the firewall. It bolts to a cover at the top of the firewall under the A/C line and only the connector is visible from the engine side. I feel better now that I found it, I beginning to think I was going blind.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
50monte
Dec 26, 2015 08:50 PM
jtscottak
Dec 2, 2014 10:13 AM
reamer
Ford Truck Parts for Sale
Apr 5, 2014 09:35 AM
reamer
36
Apr 2, 2014 08:19 PM
lars of colorado
Dec 8, 2010 09:48 AM
