PDA
View Full Version : 1947 and Older Ford Trucks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 [155] 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172
  1. 35 pickup engine swap
  2. Whats its Value??
  3. 1941 Ford 1 ton grille neeeded!!!
  4. 38 39 brakes question
  5. 38 Ford 1/2 Ton Frame
  6. help to decode 1940 ford vin#
  7. My First Old Ford
  8. '42 truck w/ flathead v8 has trouble starting
  9. 1940 radiator support
  10. 42-47 owners
  11. original tire size for 47 1 1/2 ton
  12. Ignition or carburetion?
  13. 1932 ford truck cab wood blocks/ mounting wood
  14. Need 6 used tires
  15. 46 drive shaft & 8 inch rear end
  16. 1941 1/2 ton
  17. Compression testing a flathead 4 cyl?
  18. 1926 model T
  19. 1939 to 1941 Ford 1/2 rear Fenders
  20. 1940 Pickup patch panels
  21. 46 pickup weight
  22. Noticed you discussing upholstery....
  23. 1932 ford pickup ( headliner) ?
  24. 1940 and 41 Sedan Delivery's
  25. 6 volt booster?
  26. Any hints on installing a 1979 camaro front stub on a 1945 ford p/u ?
  27. 42 1 1/2 ton 134" to 122'
  28. 1945-46 ford 1/2 ton pickup rear differential,how to figure the ratio ?
  29. drop axle
  30. 1940 Ford 1/2 Ton Panel Truck Seats
